110 or 140 MPH Spedometer/Gauge cluster
PostPosted: Mon Oct 24, 2005 4:05 am    Post subject: 110 or 140 MPH Spedometer/Gauge cluster Reply with quote
That's right, I"m looking for one, Hopefully one that everything works on, but if just the spedometer/trip odometer work, that's fine
you can contact me @ TheKobaltDuck@Msn.com
Jess
Administrator
PostPosted: Mon Oct 24, 2005 11:34 am    Post subject: Reply with quote
I have a 140 cluster from an 86 Trans Am, just have to dig it up and check teh condition.
PostPosted: Mon Oct 24, 2005 12:38 pm    Post subject: Reply with quote
going into an 84 camaro, are they interchangable? I always thought the T/A's had a different face on them.
PostPosted: Mon Oct 24, 2005 2:46 pm    Post subject: Reply with quote
the 84s did look a little different from the 86's if you swap the whole cluster you will have the better looking guages in my opinion.
also. just an FYI all you need to do the conversion is the imprinted curcuit board from the 110/140MPH speeedo and faceplate. when i did this swap i got a cluster with a bad motor, so i reused my entire cluster except the face and computer chip bit. this way i did not need to dink with the odomiter.
while i had the donor cluster i took a snapshot that is in my sig (the speedo part) my car does not have 349K on it. Very Happy
PostPosted: Mon Oct 24, 2005 5:20 pm    Post subject: Reply with quote
I don't think you can put the Birdie cluster in the Camaro.
PostPosted: Mon Oct 24, 2005 7:46 pm    Post subject: Reply with quote
ooohhhhhh.... reading helps. no the clusters are completly different.
PostPosted: Wed Oct 26, 2005 5:54 pm    Post subject: Reply with quote
Yeah after GM perfected the Camaro they used all of the left over second rate ideas and pieces to make Firebirds. Laughing
alekzaovich123
PostPosted: Tue Nov 08, 2005 11:57 am    Post subject: Reply with quote
I've got the complete working cluster. 100 Bucks.
PostPosted: Tue Nov 08, 2005 6:46 pm    Post subject: Reply with quote
I can honestly say I've never heard "perfect" and "camaro" in the same sentence. Smile
PostPosted: Tue Nov 08, 2005 9:00 pm    Post subject: Reply with quote
i got a cluster out of a 91 RS
