Posted: Mon Oct 24, 2005 4:05 am Post subject: 110 or 140 MPH Spedometer/Gauge cluster |
That's right, I"m looking for one, Hopefully one that everything works on, but if just the spedometer/trip odometer work, that's fine
you can contact me @ TheKobaltDuck@Msn.com _________________
Jess Administrator
Joined: 24 Nov 2003 Posts: 429 Location: Mount Vernon, WA
Posted: Mon Oct 24, 2005 11:34 am Post subject: |
| I have a 140 cluster from an 86 Trans Am, just have to dig it up and check teh condition. |
Posted: Mon Oct 24, 2005 12:38 pm Post subject: |
going into an 84 camaro, are they interchangable? I always thought the T/A's had a different face on them. _________________
Posted: Mon Oct 24, 2005 2:46 pm Post subject: |
the 84s did look a little different from the 86's if you swap the whole cluster you will have the better looking guages in my opinion.
also. just an FYI all you need to do the conversion is the imprinted curcuit board from the 110/140MPH speeedo and faceplate. when i did this swap i got a cluster with a bad motor, so i reused my entire cluster except the face and computer chip bit. this way i did not need to dink with the odomiter.
while i had the donor cluster i took a snapshot that is in my sig (the speedo part) my car does not have 349K on it.  _________________ 86' firebird (Junked in 2015). 88' GTA (sold in 2020).
Posted: Mon Oct 24, 2005 5:20 pm Post subject: |
| Quasi-Traction wrote: | | going into an 84 camaro, are they interchangable? I always thought the T/A's had a different face on them. |
I don't think you can put the Birdie cluster in the Camaro. |
Posted: Mon Oct 24, 2005 7:46 pm Post subject: |
| ooohhhhhh.... reading helps. no the clusters are completly different. |
Posted: Wed Oct 26, 2005 5:54 pm Post subject: |
Yeah after GM perfected the Camaro they used all of the left over second rate ideas and pieces to make Firebirds.  |
alekzaovich123 Member
Posted: Tue Nov 08, 2005 11:57 am Post subject: |
| I've got the complete working cluster. 100 Bucks. |
Posted: Tue Nov 08, 2005 6:46 pm Post subject: |
| rjmcgee wrote: | Yeah after GM perfected the Camaro they used all of the left over second rate ideas and pieces to make Firebirds.  |
I can honestly say I've never heard "perfect" and "camaro" in the same sentence.  |
BigDaddyVu 12sec Club
Posted: Tue Nov 08, 2005 9:00 pm Post subject: |
i got a cluster out of a 91 RS _________________
