		| Author | Message |
		| BluFbdy Member
 1989  Chevrolet  Camaro RS
				|  Posted: Fri Jul 22, 2011 11:15 pm    Post subject: New member and car amongst us 89 SSA Firebird! |   |
				| My buddy chris moved up here from az, we rebuilt his GTA down there and he ended up selling it after overhauling the motor putting a ton of money in and his trans destroyed itself, hes living with me up here now and we just picked him up an 89 SSA firebird
 *ORIGINALLY* its supposed to be a v6 with a sport packaged so it looked like the trans am
 *NOW*
 Its got a 305 tbi in it, looks like a complete harness and motor swap, it has a NAAASSSSTY TBI  on it, all gunked up, random wires ive picked thru and an exhaust leak because the air tubes are missing from the factory manifolds, the exhaust has kink bent autozone tubing thats all gonna get redone eventually. Its got the triganlge edelbrock filter on it currently with the IAT just tied up in the engine bay and the 02 sensor is just plain not wired up
 Its throwing 2 codes, 13, and 23, explained reasons above so theyre easy fixes, were just gonna throw a bolt in the factory manifold hole and get rid of the massive exhaust leak, throw some seafoam in it and give it some good TLC and itll be golden mechanically
 The front clip is cracked not worth repairing IMO, and the passenger side fender is pushed in, either find a new one or repair it havent decided yet
 Car is a rattle can 2 tone and i think we're gonna experiment with the tracot paint job over on tgo (i was impressed for the $ invested)
 And the interior is pretty damn solid except for the back seat that folds has a tear across the top, were taking it to work on sunday and spraying all the crap off of it with the pressure washer.
 some needed parts to track down are gonna be v8 springs, large sway bars (still has v6 suspension! >_<) front clip, and maybe a fender
		| Back to top |  |
		| Al Hasse Member
 1992  Chevrolet  Camaro RS
				|  Posted: Sat Jul 23, 2011 5:04 am    Post subject: |   |
				| I have a set of those manifolds, with AIR tubes sitting in the garage.  Also, if interested, I have a set of stock V8 springs, they're a bit on the soft side being RS springs though.
 Oh, and a welcome aboard too!!!
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Sat Jul 23, 2011 5:26 am    Post subject: |   |
				| I have a Z28 front sway bar here. Also some worn Z28 springs. Scrap metal prices for 'em since that's where they were headed.  |  |
		| Back to top |  |
		| redlava Member
 1986  Chevrolet  Camaro Z/28
				|  Posted: Sat Jul 23, 2011 5:58 am    Post subject: |   |
				| I have some z-28 springs at my parents house in Vancouver. They are coming up to Bremerton, the middle of next month. Just another option with a shorter drive. I'll let them go for 10 bucks. |  |
		| Back to top |  |
		| soocrispy89 New Member
 1989  Pontiac  Firebird
				|  Posted: Sat Jul 23, 2011 7:51 am    Post subject: ssa |   |
				| Al Hasse I'll take those manifolds and air tubes. how much are you looking for? and i might take you up on those rs springs if i cant get some stiffer ones. Aaron_sK how much would you want for that sway bar? And redlava ill take those z28 springs, just let me know when you wanna meet up. Thanks guys for all the help. _________________
 If It's TOO LOUD your TOO OLD!
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Sat Jul 23, 2011 8:12 am    Post subject: Re: ssa |   |
				|  	  | soocrispy89 wrote: |  	  | how much would you want for that sway bar? |
 10 bucks I guess? I dunno.
		| Back to top |  |
		| BluFbdy Member
				|  Posted: Sat Jul 23, 2011 8:12 am    Post subject: |   |
				| Chris I thought we were just rigging up the manifold? _________________
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Sat Jul 23, 2011 8:21 am    Post subject: |   |
				| Plugging manifolds can be done from the top. No reason to replace them unless he's building an emissions car and the threads in his current logs are buggered. |  |
		| Back to top |  |
		| Al Hasse Member
				|  Posted: Sat Jul 23, 2011 9:37 am    Post subject: Re: ssa |   |
				|  	  | soocrispy89 wrote: |  	  | Al Hasse I'll take those manifolds and air tubes. how much are you looking for? and i might take you up on those rs springs if i cant get some stiffer ones. |
 Well, I paid $10 for my current spring, maybe these can go for the same.  Like Aaron said, you can plug the manifolds from the to, but if you want these, maybe anothe $10 for the set.
		| Back to top |  |
		| BluFbdy Member
				|  Posted: Sat Jul 23, 2011 9:38 am    Post subject: |   |
				|  	  | aaron_sK wrote: |  	  | Plugging manifolds can be done from the top. No reason to replace them unless he's building an emissions car and the threads in his current logs are buggered. |
 Exactly my thought, we dont have an emmissions battle anymore (thank god) so plugging the air tube hole is a matter of a bolt and maybe some red thread locker? Im not sure of them temp range on them but ive got both.red and blue on hand
		| Back to top |  |
		| Al Hasse Member
				|  Posted: Sat Jul 23, 2011 9:41 am    Post subject: |   |
				| Ultra Copper.  Thats what I used for an EGR gasket on my V6, it's been holding strong for about a year now. |  |
		| Back to top |  |
		| BluFbdy Member
				|  Posted: Sat Jul 23, 2011 9:51 am    Post subject: |   |
				| Soubds good ill drill the hole for the IAT tonight and hopefully we can fet.a bolt to seal up the manifold _________________
		| Back to top |  |
				|  Posted: Sat Jul 23, 2011 12:46 pm    Post subject: |   |
				| yeah were just gonna get a bolt and delete out the tubes. and as for the springs i need some bigger ones cause of the bigger motor with all factory v6 springs. so if you just want 20 for the set im ok with that. _________________
		| Back to top |  |
		| Al Hasse Member
				|  Posted: Sat Jul 23, 2011 1:00 pm    Post subject: |   |
				| They're here, just sitting in the garage.  It's not far, Andy's been to my place. |  |
		| Back to top |  |
