popballz Member
Posted: Mon Jul 18, 2011 5:44 pm Post subject: can you weld o2 sensor to exhaust? |
if you weld an oxygen sensor straight to the exhaust then will it still function correctly? what % chance will it work alright?
and is the bend at the bottom of the engine too far to put the oxygen sensor? _________________ -Donald
Posted: Mon Jul 18, 2011 6:17 pm Post subject: |
| There are these little things called a "bung" that you weld to the pipe. Then you can screw in the O2 sensor. Better yet, you can screw out the O2 sensor. That's always a useful feature. |
Posted: Mon Jul 18, 2011 7:01 pm Post subject: |
To answer your question... If you weld directly on the sensor I would not trust it even if it still was able to somehow manage a reading. _________________ A redline a day keeps the carbon away! |
Posted: Mon Jul 18, 2011 8:05 pm Post subject: |
| QwkTrip wrote: | | Better yet, you can screw out the O2 sensor. That's always a useful feature. |
Amen to that. _________________ 84 Camaro Z28 - LS1/T56
popballz Member
Posted: Tue Jul 19, 2011 1:21 am Post subject: |
lol i looked for a bung but autozone didnt have one and lowes didnt have a big enough nut. i had a new sensor with no threads on it so i gave it a shot. i put it at the beginning of the y-pipe on the drivers side. is that close enough to not need a heated sensor?
it defently runs alot better. it has smoother acceleration and it idles good more often than not. it idles good after 190*. Would the beginning of the y-pipe be too far away to burn anything off with a cold engine?
my air filter was unbelieveably dirty so i also threw a new one of those on! _________________ -Donald
BigDaddyVu 12sec Club
Posted: Tue Jul 19, 2011 2:50 pm Post subject: |
i got a couple of bung holios for you. it came with my A/F gauge kit. _________________
Posted: Tue Jul 19, 2011 2:58 pm Post subject: |
Any muffler shop will have it. _________________ A redline a day keeps the carbon away! |
