305 T-5
1987_sportcoupe
1987 Chevrolet Camaro
PostPosted: Mon Jul 11, 2011 1:20 pm    Post subject: 305 T-5 Reply with quote
Will a T-5 from a 305 work with a 2.8? What about the clutch and hydraulics?
PostPosted: Mon Jul 11, 2011 2:45 pm    Post subject: Reply with quote
Hydraulics work fine.
You'll need to get a v8 26 spline disc, and a v6 14?iirc spline disc and have the hubs switched out.
1987_sportcoupe
PostPosted: Mon Jul 11, 2011 2:56 pm    Post subject: Reply with quote
Is that easy to do? This is my first time doing a tranny swap like this
PostPosted: Mon Jul 11, 2011 3:46 pm    Post subject: Reply with quote
Everything else is the same. The case, driveline, etc etc.
You'll need to use the speedo gear from the v6 to keep your speedometer right.
The hub switching has to be done by a professional. It takes special machines and rivets ,etc to be centered and balanced.
Find a "BRAKE AND CLUTCH" shop in your area.
PostPosted: Mon Jul 11, 2011 8:58 pm    Post subject: Reply with quote
Go to South Side Brake and Clutch if you do this. It's right off south tacoma way. 54th and S. Washington which is about a block away from 56th and ST way. Real nice people there.
PostPosted: Mon Jul 11, 2011 10:21 pm    Post subject: Reply with quote
might as well get a V6 T5, they are quite plentiful in junkyards. you can probably make money if you sell the v8 T5.
PostPosted: Tue Jul 12, 2011 5:35 am    Post subject: Reply with quote
I'm with stupid
14-splie T5's grow on trees, not worth the trouble.
PostPosted: Sat Jul 23, 2011 5:20 pm    Post subject: Reply with quote
lol, I actually answered your other post, but pretty much what everyone's said is right, go to a JY and pull a V6 T5.
Make sure its out of an F-body, as the S-10 trans has the shifter closer to the main case, and wouldn't be a direct bolt-in.
