BluFbdy Member
Posted: Sat Jun 25, 2011 1:44 am Post subject: Crane cams parts locally? |
I need to find a crane cams parts distributor locally ive sent parts back and forth to summit god knows how many times and im done with it, I need to physically hold the part before buying it I am missing ONE poly lock rocker arm nut for my motor and su,,it sent me a trick flow one that carried over as a part for cranes nut which was wrong....
Preferably in tacoma or port orchard area, ill be in tacompton tomorrow so ifi can find a place tomorrow that would be cool
Suggestions? _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Sat Jun 25, 2011 8:35 am Post subject: |
| You do know that Crane went out of business awhile ago? The people who bought most of the company have been starting to make more parts, but they still dont make everything they used to. |
BluFbdy Member
Posted: Sat Jun 25, 2011 9:45 am Post subject: |
True lol I know parts stores can order still _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Sat Jun 25, 2011 10:28 am Post subject: |
http://www.cranecams.com/locator/
Mostly dealers for bike parts, but a few small speedshops in the mix.
Also, Baxters sells Crane stuff, might try their warehouse on 9th by the freeway. |
Posted: Sat Jun 25, 2011 11:24 am Post subject: |
| Makes sense since Crane is owned by a company that makes harley parts now. |
Posted: Sat Jun 25, 2011 11:37 am Post subject: |
| Just putting a Harley Davidson sticker on your truck can make you 75% more likely to be found stranded on the side of the road. Imagine what happens if you use their parts. |
BluFbdy Member
Posted: Sat Jun 25, 2011 11:43 am Post subject: |
Haha well I went to promax in tacoma and I got a set of rocker nuts from them, proform so ill see how well it works out lol I just matched the size the trick flows were way too big for the slot on the rocker arm _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Sat Jun 25, 2011 5:48 pm Post subject: |
| BluFbdy wrote: | | Haha well I went to promax in tacoma and I got a set of rocker nuts from them, proform so ill see how well it works out lol I just matched the size the trick flows were way too big for the slot on the rocker arm |
I used to go to Promax. They are such a rip off! How much you pay for those nuts? _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Sun Jun 26, 2011 6:19 am Post subject: |
Hehe... 'The NLN' charges fifteen dollars a nut, plus a service fee.  |
Posted: Mon Jun 27, 2011 4:06 pm Post subject: |
| QwkTrip wrote: | | Just putting a Harley Davidson sticker on your truck can make you 75% more likely to be found stranded on the side of the road. Imagine what happens if you use their parts. |
I still have a couple bottles of their cam break in lube. Older stuff with the right ZDDP levels for flat tappet cams. |
BluFbdy Member
Posted: Mon Jun 27, 2011 7:45 pm Post subject: |
20 bucks for the set, not bad lol I used to see tons of shops like that in az, all I can find here are like oriely, autozone and westbay I m having performance shops close to me, I uswd to go to aztpi and lopers never dealt with the large chains _________________ If you expect a kick to the balls and get a slap to the face its still a victory
