		| Author | Message |
		| Al Hasse Member
 1992  Chevrolet  Camaro RS
				|  Posted: Sun Jun 19, 2011 2:36 pm    Post subject: Another massive oil leak... |   |
				| Probably not as bad as John's, but bad enough.  Looking under the car while idling and it almost looked like the rear main seal leaking.  I know it's possible, but with just 50K on the motor I kind of doubt it. It was dripping all over the oil pan, K-member and Y-pipe and burning off with the hot exhaust.  I got to looking a bit more and found where I think the leak is.  The block that the oil filter and OPSU are mounted to is leaking where it meets the engine block.  Since it's time to change oil anyhow, I may as well do this at the same time.  Just have to keep it full until next weekend. _________________
		| Back to top |  |
		| aaron_sK Member
		| Back to top |  |
		| Al Hasse Member
				|  Posted: Sun Jun 19, 2011 4:43 pm    Post subject: |   |
				| Had to order the gasket anyhow, so looks like I have to make sure it stays full for the next day or so... |  |
		| Back to top |  |
		| Al Hasse Member
				|  Posted: Tue Jun 21, 2011 7:24 pm    Post subject: |   |
				| That, I think is taken care of.  The job actually wasn't all that difficult, except for scraping the old gasket away from the block - no good angle to get there and no leverage to scrape.  And I got a nice burn on my wrist since the motor was still warm, I would have lost daylight otherwise.  Let her idle for a while, so far no drips and the oil pain which I wiped dry was still dry. |  |
		| Back to top |  |
