badbob66 Member
Joined: 27 Mar 2005 Posts: 134 Location: Damascus, Oregon
Posted: Fri Jun 03, 2011 2:46 pm Post subject: aluminum rear brake drums |
for sale is two set's of aluminum brake drums, 4 brake drums total.
They are in good shape, 2 drums need to be turned just to get the rust off the braking surface NOT because they are worn badly.
$30.00 for all 4 drums.
Located in Camas , WA.
Thanks
Bob _________________ 1986 trans am
1985 Honda fl350 Odyssey(No it's not a MINI VAN)
1985 honda 250R ATC
badbob66 Member
Posted: Tue Jun 07, 2011 7:11 pm Post subject: brake drums |
brake drum pic  _________________ 1986 trans am
1985 honda 250R ATC |
Posted: Tue Jun 07, 2011 7:23 pm Post subject: |
Can you hold on to the drums for a bit? Mine have been turned for the last time and I'm thinking of replacing them very soon. I'm having issues with the rears randomly locking before the fronts, I know it's the star wheel adjustment, but can't get it right for some reason. _________________ 92 Camaro
Posted: Tue Jun 07, 2011 7:56 pm Post subject: |
| Al, you most likely arent getting the brakes tight enough. It's counter-intuitive. Drum brakes are self actuating. The more movement they have, the more cam action there is to lock them into the drum. You want to tighten them up till the drum is locked.. then just back them off a few clicks. |
Posted: Tue Jun 07, 2011 8:01 pm Post subject: |
| Thanks Brandon. That does seem odd. So they're not tight enough for the self adjusters to work correctly? I still need new drums soon. |
badbob66 Member
Posted: Wed Jun 08, 2011 5:46 pm Post subject: |
| Al Hasse wrote: | | Can you hold on to the drums for a bit? Mine have been turned for the last time and I'm thinking of replacing them very soon. I'm having issues with the rears randomly locking before the fronts, I know it's the star wheel adjustment, but can't get it right for some reason. |
When do you want to get them? I can hold them for awhile, I'M moving in July and need to get rid of all my extra parts.
Thanks
Posted: Wed Jun 08, 2011 9:10 pm Post subject: |
| By the end of the month, no later. I'll give you a heads up when I can come down. Thanks. |
badbob66 Member
Posted: Thu Jun 09, 2011 5:59 am Post subject: |
| Al Hasse wrote: | | By the end of the month, no later. I'll give you a heads up when I can come down. Thanks. |
OK, sounds good I will hold them for you.
Thanks
