Speedometer gear
PostPosted: Mon Apr 18, 2011 10:18 pm    Post subject: Speedometer gear Reply with quote
Looking to see if somebody has one lying around for a T5 car w/ electronic speedo and 3.23 gears out back. I would be very interested thanks!
Leejo2005
PostPosted: Tue Apr 19, 2011 6:31 pm    Post subject: Reply with quote
That's a shame I'm taking out the gears from my t5 for 3.23 gears but they are for mechanical speedo, although I have an electronic sender attached to it.
2010 Cobalt LT
1999 Taurus SHO
1974 F-250 460
1967 Satellite Sport 383
PostPosted: Tue Apr 19, 2011 7:31 pm    Post subject: Reply with quote
From what I hear finding VSS speedo gears is like trying to find a needle in a haystack. Good luck.
I have a spare 3.23 mechanical speedo gear too. Razz
91camaro_rs
PostPosted: Tue Apr 19, 2011 9:57 pm    Post subject: Reply with quote
i have one for 3.23 but its for a 700r4
PostPosted: Mon Apr 25, 2011 9:43 am    Post subject: Reply with quote
Try giving these people a call.
http://www.transmissioncenter.net/speedometer_calibration_______va.htm#350
PostPosted: Wed Apr 27, 2011 2:19 pm    Post subject: Reply with quote
Dammit, yeah I guess they are hard to find, I looked at that site, it made me more confused. If I call them, will they help me find one? lol
PostPosted: Wed Apr 27, 2011 5:23 pm    Post subject: Reply with quote
http://www.tciauto.com/Products/TechInfo/
Use this to find your aspect ratio based tire diameter.
Then use it to find your speedometer gear you need.
Then you can call up and say I need a VSS Speedo gear for a F-body T-5 with X-teeth.
PostPosted: Wed Apr 27, 2011 11:32 pm    Post subject: Reply with quote
Start calling the local trans supply shops. I found a used drive gear at this place. I also placed ads on CL, TGO, here, and a wanted ad on Ebay.
http://www.txchange.com/
PostPosted: Sun May 08, 2011 10:01 am    Post subject: Reply with quote
So I found that our 245/50/16s are 25.65" tall so all I need to know is how many teeth the drive gear has to complete the formula. Does anyone know this number? I don't really want to drain fluid to count the teeth unless I have too.
The gear that is in the car now is from a V6 car that had 3.42's so it reads slow.
*Edit. Nevermind I found that I have a 7 tooth drive gear and need the 18 tooth driven gear, now I should be able to order it. lol
PostPosted: Sun May 08, 2011 10:36 am    Post subject: Reply with quote
You don't have to drain the fluid. Remove the speedo cable and speedo bullet and take a flashlight and look in the hole. You may lose a little fluid but not much. More than likely it's blue 7 tooth drive gear.
PostPosted: Sat May 14, 2011 9:24 pm    Post subject: Reply with quote
I ended up giving them a call, a guy with a heavy southern accent said they don't have one available at all, he kept thinking I had a mustang T5, had to correct him like 3 times Rolling Eyes
PostPosted: Sat May 14, 2011 9:43 pm    Post subject: Reply with quote
I ordered mine from PATC. You can use the gear for a TH350. Scroll down to the T5 stuff, you can use the TH350 driven gear if you also get the gear housing for the TH350. Might be a bit tricky though getting the VSS style.
