		| Author | Message |
		| Sellmanb Member
				|  Posted: Thu Apr 07, 2005 4:45 pm    Post subject: Single person trans install? |   |
				| So I'm going to put my trans back in on Saturday, and I'm not too sure I can do it alone, but dont want to have to call on any help if I can help it.
 I've got a jack and my only piece of wood that's the right size holding the engine up right now. I have another jack though that I can use. I figured I would just benchpress the trans up if I could (it only felt about 90lbs w/o torque converter, and 110 w/), then try to hold it up with one hand, and one shoulder, and thread in some bellhousing bolts while I could...
 I'm probably gunna kill myself in this route, so I was curious if anyone had any better ideas!
 Thanks in advanced... I really wanna make this dyno.
		| Back to top |  |
		| Slowbird New Member
				|  Posted: Thu Apr 07, 2005 5:47 pm    Post subject: |   |
				| I wouldn't do it alone. It's much easier to call a friend now than call one from the hospital. I read online somewhere that the 700r4 weighs 155lbs, so it's not something you want falling on your head when no help is around. I did it myself, but I used a tranny jack. They're about $40 at most places and real usefull....
 -Andy
		| Back to top |  |
		| rjmcgee The Hammer
				|  Posted: Thu Apr 07, 2005 5:57 pm    Post subject: Re: Single person trans install? |   |
				|  	  | Sellmanb wrote: |  	  | I figured I would just benchpress the trans up if I could (it only felt about 90lbs w/o torque converter, and 110 w/), then try to hold it up with one hand, and one shoulder, and thread in some bellhousing bolts while I could...
 If you try that your gonna die
 In the last year I have had my T5 in and out a couple times and that is how I do it, the benchpress method and it is all the weight I really want to hold over my head while trying to start the bolts. Plus the T5 weights maybe half what an auto weights, so I don't think that you could do it.
 Of coarse I'm just a scrawny little bastard too.
		| Back to top |  |
				|  Posted: Thu Apr 07, 2005 6:53 pm    Post subject: Re: Single person trans install? |   |
				|  	  | rjmcgee wrote: |  	  |  	  | Sellmanb wrote: |  	  | I figured I would just benchpress the trans up if I could (it only felt about 90lbs w/o torque converter, and 110 w/), then try to hold it up with one hand, and one shoulder, and thread in some bellhousing bolts while I could...
 I can press a T5 no problem. The Tremec TKO I could do if I had it on my chest to start but that fugger is heavy. AN AUTO?! HAIL NO! MAYBE A GLIDE MAYBE?! B?
 Dude, use the jack. If I had the day off I'd come give you a hand but I've got to work until 7 then I'm off to see a friend in a concert.
		| Back to top |  |
		| Sellmanb Member
				|  Posted: Fri Apr 08, 2005 10:55 am    Post subject: |   |
				| allright, so skinny ass (5 foot 9, 130 lbs) + benchpress 150lb trans = dead skinny ass... gotcha lol.
 I'll get another piece of wood to use with my other jack, and put the tranny on top of it and give it a whirr. Will update how it goes on Saturday
		| Back to top |  |
		| Sellmanb Member
				|  Posted: Thu Apr 14, 2005 4:10 pm    Post subject: |   |
				| So I ended up grabbing a coworker after work, and had him help me with it. We put the tranny under the car, put a creeper by the tranny, tilted the tranny on it's side, and layed in on the creeper. We then put a long breaker bar under the tranny to tilt the top end up.
 Then we just lowered the car until we could just slide it in and bolt it in.
 It was verrrry easy, and sadly I could have done it myself, just needed another person's innovation I guess.
		| Back to top |  |
		| alloy T56 Elitist
				|  Posted: Thu Apr 14, 2005 4:13 pm    Post subject: |   |
				| Well just think of it this way, if something had gone wrong, you had help there. Alone you could be laying there trapped under a trans with no one to call for assistance  |  |
		| Back to top |  |
