nonsensekid20 Member
Posted: Thu Mar 17, 2011 4:43 pm Post subject: 2in cowl hood |
Air cleaner don't fitt. Need a cowl hood.  |
Posted: Thu Mar 17, 2011 10:31 pm Post subject: |
Or a drop base.  |
Posted: Fri Mar 18, 2011 3:39 pm Post subject: |
| aaron_sK wrote: | Or a drop base.  |
^ this. _________________
Posted: Fri Mar 18, 2011 9:10 pm Post subject: |
Can you buy just the base? cause I have the air cleaner already, and they're perty expensive. Not that I have money for either the hood or a new air cleaner, I could get a new base if i can.
Edit: Do they only come in round? I have an oval filter.. |
Posted: Fri Mar 18, 2011 9:23 pm Post subject: |
| You might be able to find a oval one, just search for a style you like, and find a drop base... they are a heck of a lot cheaper than a hood...and painting a hood, though. |
Posted: Fri Mar 18, 2011 9:25 pm Post subject: |
i've been lookin around. Went to a cobra website, those guys were sayin you couldnt do a drop base with an oval because the throttle linkage would get in the way. Some guy fabricated one, but i can't exactly fabricate.
http://www.clubcobra.com/forums/showthread.php?t=83270 |
RK82 Member
1982 Pontiac Trans Am
Posted: Sat Mar 19, 2011 7:06 pm Post subject: |
| what intake do you have? |
Posted: Sat Mar 19, 2011 10:27 pm Post subject: |
Also, how tall of an element?
People think they need a huge thing on there. I run the 390 to six grand with a 14x2".  |
Posted: Sat Mar 19, 2011 11:17 pm Post subject: |
| aaron_sK wrote: | Also, how tall of an element?
I just barely cleared with a 14X3 element. I'll go to 14X2 with the new motor if clearance is an issue. _________________ 92 Camaro
Posted: Sat Mar 19, 2011 11:57 pm Post subject: |
| It's a 2" element. And I think its a stock replacement intake. for TBI anyway. I ended up putting my triangle of death back on. Foam is still soft so I think im good for awhile. But even that barely fits under my hood. |
RK82 Member
Posted: Sun Mar 20, 2011 9:07 am Post subject: |
| nonsensekid20 wrote: | | It's a 2" element. And I think its a stock replacement intake. for TBI anyway. I ended up putting my triangle of death back on. Foam is still soft so I think im good for awhile. But even that barely fits under my hood. |
you probably just need a drop base, I've got an edelbrock EPS intake, 1 inch carb spacer with a moroso drop base with a 14x3 filter, the top of the air cleaner just barely rubs the bottom of the hood. |
Posted: Sun Mar 20, 2011 9:09 am Post subject: |
| Al Hasse wrote: |
I just barely cleared with a 14X3 element. I'll go to 14X2 with the new motor if clearance is an issue. |
With an airgap, you'll need a 2" element. You'll probably have less than 1/2" clearance between the center post on the TBI unit and the ribbing inside the hood. _________________
Posted: Sun Mar 20, 2011 11:26 am Post subject: |
| Another thing to take a look at is that some filter bases are more level, and some are actually pushed upwards. I can't run a drop-base on the Merc because of the mechanical throttle linkage, but a flat one works great. |
Posted: Mon Mar 21, 2011 3:37 pm Post subject: |
| But do they make drop bases for oval air cleaners? |
RK82 Member
