fiveoformula Member
Posted: Wed Mar 09, 2011 8:26 pm Post subject: My S-10 refuses a speedo. |
So I bought this '88 S10 really cheap, and the brilliant guy who replaced the tranny cut the speedometer cable. no big deal I figure I'll just get a new cable and put it in. When I did it the first time after a few minutes of driving, I notice a ticking noise that gets louder the faster I drive. I go back to the cable and look and failed to notice how close I routed it to the exhaust. So I grab another 10 dollar cable and route it better and it still ticks! and the needle bouces around really bad, and when I drive it like this, it feels like it keeps locking and unlocking the torque converter, either that or its actually downshifting and upshifting erratically.. Anyone fight a problem like this before? could the cluster just have a problem? What will make the needle jump so much? _________________
'88 FORMULA |
Posted: Wed Mar 09, 2011 8:46 pm Post subject: |
Since it's the same with more than one cable, maybe check the condition of the driven gear. Hole for the cable stripped out?? Maybe the speedo itself like you said. _________________ 92 Camaro
Posted: Wed Mar 09, 2011 8:52 pm Post subject: |
If the speedo is bouncing its usually a sticky speedometer cable. Since the cable is new I'd pull the bullet out and inspect the teeth like AL said. If that's good, it's the speedo itself. _________________ A redline a day keeps the carbon away! |
fiveoformula Member
Posted: Wed Mar 09, 2011 9:09 pm Post subject: |
| Well it isn't quite as loud with this cable, the last one was really bad. So I will check out that drive gear. With the cable unplugged, does the torque converter not lockup? |
Posted: Wed Mar 09, 2011 9:51 pm Post subject: |
The converter (and a lot of other stuff in the ECM) relies heavily on the VSS.
Are these cables pre-lubed? Dry cables stick, then bounce up like you describe. |
Posted: Wed Mar 09, 2011 11:39 pm Post subject: |
Cable setups use a VSS buffer from the speedometer, not from the trans output itself. _________________ A redline a day keeps the carbon away! |
Posted: Thu Mar 10, 2011 6:26 am Post subject: |
| Twilightoptics wrote: | | Cable setups use a VSS buffer from the speedometer, not from the trans output itself. |
I know, I've had several of them.
The ECM is still retarded without it. If the cable breaks the timing curve, idle speed and torque converter lockup goes in the toilet. |
