my boss' car is acting up
91camaro_rs
PostPosted: Wed Mar 02, 2011 1:48 pm    Post subject: my boss' car is acting up Reply with quote
so its a 93 ford exploder, and it seems like it has a loss of power, and when you get on the throttle the engine light sorta flickers and the oil pressure guage jumps way down and starts pinging up and down real fast. so im thinkin its a bad oil pressure sensor
also it has way to much tranny fluid, whoever checked it before must have checked it while it was cold and not running
PostPosted: Wed Mar 02, 2011 4:19 pm    Post subject: Reply with quote
Oil pressure sensor isn't going to cause pinging.
PostPosted: Wed Mar 02, 2011 5:49 pm    Post subject: Re: my boss' car is acting up Reply with quote
Sounds like bad ground connection, corroded battery cables, bad alternator, something with a poor electrical connection. Especially if it kinda misses and runs bad at the same time as a flickery engine light and wacko gauges.
PostPosted: Wed Mar 02, 2011 7:35 pm    Post subject: Reply with quote
I'm with stupid
90's Ford's tend to have crap battery connections. Always all corroded and crappy.
PostPosted: Wed Mar 02, 2011 9:52 pm    Post subject: Reply with quote
i worked on an explorer where the starter had 12v but the main positive battery cable was so corroded it wouldn't even crank. just something to keep in mind.
-Donald
91camaro_rs
PostPosted: Thu Mar 03, 2011 12:51 am    Post subject: Reply with quote
i did notice that the battery terminals were a bit corroded, ill check em out next time im driving it
i had prom error code 51 on my way home today, interesting ride thing was like a bucking bronco lol
re-burned the chip and now its fine
