Headlights
nonsensekid20
PostPosted: Thu Feb 17, 2011 8:33 pm    Post subject: Headlights Reply with quote
So I wanted to get ones with the LED's around the outside.
Ideas? links?
91camaro_rs
PostPosted: Thu Feb 17, 2011 10:39 pm    Post subject: Reply with quote
like mine?...ebay
townaj
PostPosted: Sun Feb 20, 2011 4:56 pm    Post subject: Reply with quote
I got mine from the seller prostreetlighting on ebay. They have the blue leds. But the headlight bulbs blow on low.
PostPosted: Sun Feb 20, 2011 7:23 pm    Post subject: Reply with quote
The headlight bulbs are fine. It's the pattern of the cheap ebay housings.
townaj
PostPosted: Mon Feb 21, 2011 2:10 pm    Post subject: Reply with quote
yeah true. im gonna do projectors eventually though so it doesnt bother me much. and i live in the country so i usually use my high beams. those are bright as crap and have a good spread.
91camaro_rs
PostPosted: Mon Feb 21, 2011 10:30 pm    Post subject: Reply with quote
thats why i went HID Very Happy
townaj
PostPosted: Tue Feb 22, 2011 8:29 am    Post subject: Reply with quote
I just liked the blue glow haha. Even though I'm pretty sure its illegal
nonsensekid20
PostPosted: Tue Feb 22, 2011 2:18 pm    Post subject: Reply with quote
Well I tried summit. but, no luck. ):
HID's are lookin bright in my future. Laughing
PostPosted: Tue Feb 22, 2011 4:43 pm    Post subject: Reply with quote
Don't do HID's unless you do the proper housings and aiming for them. All you do is blind oncoming drivers, without giving yourself any usable light.
nonsensekid20
PostPosted: Tue Feb 22, 2011 5:09 pm    Post subject: Reply with quote
Like what? is there a company that makes housings for our cars?
PostPosted: Tue Feb 22, 2011 5:11 pm    Post subject: Reply with quote
Many of the H4 conversions are misidentified as HID, or as having the HID look. Again, most not much good.
PostPosted: Tue Feb 22, 2011 5:12 pm    Post subject: Reply with quote
No one really makes housing for our cars, but you could build a housing, then use a projector with the proper D2S or H1 for the projector being used. Headlights are designed for a certain bulb. Putting an HID bulb in a housing for something, just scatters light all over, it doesn't light the road any better.
PostPosted: Tue Feb 22, 2011 5:17 pm    Post subject: Reply with quote
If I got my info correct, HID lights require a projector, what is called a Bi-Xenon might work in an H4 housing with the right type of reflector.
PostPosted: Tue Feb 22, 2011 5:29 pm    Post subject: Reply with quote
there are several types. D2R bulbs are meant to be used in a reflective housing (think STi type headlights), but are different than say an H4, so they dont really work right in an H4 housing. D2S are for projector housings (think Audi/BMW type headlights). The projectors are just much easier to retrofit with. bi-xenon's just mean that using the same housing, they move the aim-point of the light to provide the hi-beam, instead of using a second bulb. Normally this is done with a noid that opens the cut-off shield used on the low-beam.
--John
PostPosted: Tue Feb 22, 2011 6:15 pm    Post subject: Reply with quote
I haven't seen many H4 to HID back to back. All I can say, is if you are upgrading to an H4 housing.... DO NOT CHEAP OUT on the housings. Plus, you need to run relays to operate the headlights, so all the extra power form the H4 doesn't ruin your headlight switch.
I can't imagine HID retrofitted into an H4 housing, being any brighter than a properly equipped H4 bulb...... in a good H4 housing.
nonsensekid20
PostPosted: Tue Feb 22, 2011 7:20 pm    Post subject: Reply with quote
Luke did something like that.
Not sure I'm crazy about the black housing.
http://cgi.ebay.com/ebaymotors/H4-HEADLIGHTS-CONVERSION-KIT-CRYSTAL-BLACK-DIAMOND-CUT-_W0QQcmdZViewItemQQfitsZModelQ3aCamaroQ7cMakeQ3aChevroletQQhashZitem2eb36ca978QQitemZ200578738552QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Whiskeychick
1987 Pontiac GTA
PostPosted: Tue Feb 22, 2011 11:17 pm    Post subject: Reply with quote
Hella, and Cibie make good housings for our cars. I just got a complete H4 relay conversion for my firebird from Daniel Stern.
Fantastic site, TONS of info on lighting.
And its all plug and play, no cutting of my stock wiring harness, and still uses the orignal switches.
I opted for Cibie housings, 75 bucks a piece, but Hella are good construction as well, and a lot cheaper.
And I will be running a 90/100w bulb.
But as was said before, HID is a waste of time unless you have the proper housings etc for them.
Also those ebay diamond cut ones, are absolute garbage. They scatter the light everywhere, blinding the other drivers, and do nothing for your visability. And actually in heavy rain, you have NO visability. I know a few people that have used them and taken them back out the next day, because they look cool, but dont actually help for visability.
91camaro_rs
PostPosted: Tue Feb 22, 2011 11:44 pm    Post subject: Reply with quote
i got cheap ebay halo housings and bought h4 HID's and they are aimed fine, and are wayyyyy brighter than stock H4 and visibility is wayyy better
im kinda confused with the proper housing thing cause i have no problems with mine, nobody flashes me for brightness or anything and my friends who have seen me driving say it doesnt blind them, im sorry its just hard for me to agree with all this stuff because i have HID's in diamond cut ebay housings and they are totally fine, SUPER bright, visability is amazing, im totally satisfied with my setup
PostPosted: Tue Feb 22, 2011 11:45 pm    Post subject: Reply with quote
As far as I know there is ONE company that makes a 4656 replacement with bi-xenon HID setup. Last I looked it was ~$550 for a single headlight. There is a guy on TGO that does retrofits for people. Pretty affordable too, I think. 84 1LE; http://www.thirdgen.org/techboard/auto-detailing-appearance/522825-projector-retrofit-inside-w.html
I have HIDs in a freeform housing and I like it. A good bit brighter than my previous high output H4s from rallylights.com (which put out a significant more lumens than a standard H4 at similar wattage). I'd love to do an HID retro but I'm having a hard time finding an OEM projector that will fit in a firebird headlight. The DDM HID kit I have uses a shield that blocks a lot (no where near all) of the upward light that scatters.
91camaro_rs
PostPosted: Tue Feb 22, 2011 11:48 pm    Post subject: Reply with quote
i took the metal deflectors off of my bulbs,
