3-series 9-bolt
PostPosted: Tue Feb 15, 2011 1:03 pm    Post subject: 3-series 9-bolt Reply with quote
If anyone comes across a good deal on a 3-series 9-bolt rear or has one stuck away somewhere, keep me in mind and help a crewbie out. Very Happy
I don't wanna blow up my 10-bolt. Rolling Eyes Burnout
PostPosted: Tue Feb 15, 2011 6:39 pm    Post subject: Reply with quote
There was just a dude on here selling a 3.73 niner.
*Edit: Like so...
http://cascadecrew.org/phpBB2/viewtopic.php?t=7756
Also, if you want a spare 10 bolt to break there's always my old one. Wink
PostPosted: Tue Feb 15, 2011 11:49 pm    Post subject: Reply with quote
*Edit: Like so...
I would quite enjoy breaking your 10-bolt Aaron. Let's do it with your project car... Very Happy
PostPosted: Wed Feb 16, 2011 8:28 am    Post subject: Reply with quote
Project car is getting a nine. I'm picking it up at dyno. Wink
PostPosted: Wed Feb 16, 2011 10:13 am    Post subject: Reply with quote
Exactly. Put the 9 in after you break the 10. I wish I would have jumped on that rear before you did.. Wink
redlava already sold his, I asked. Sad
PostPosted: Wed Feb 16, 2011 10:21 am    Post subject: Reply with quote
Get a girdle and the only way you'll break the 10bolt is with slicks and a 3000rpm clutch drop.
PostPosted: Wed Feb 16, 2011 11:16 am    Post subject: Reply with quote
I might just do that. Only problem is I know at least a few 3-4k clutch drops on drag radials are in my future. 4thgen guys do run these late 10-bolt rears pretty fast however, I might be fine. Smile Maybe I should spend the cash on beefing up the 10-bolt a bit instead of buying a used 9-bolt.
PostPosted: Wed Feb 16, 2011 11:48 am    Post subject: Reply with quote
You wont be fine.
300rwhp at the time.
3k launch with clutch
Each time broken axles. Happened 3 times.
On the third time, I found the Eaton Pinion gear cracked in 3 places.
Launch with an automatic, or street tires - can't hook up enough to hurt it.
