redlava Member
Posted: Sun Oct 03, 2010 5:57 pm Post subject: Scored at the JY....kinda |
Found a 9 bolt 3.70 rear at the junk yard in tumwater. After checking the posi, I ended up bringing the rear home. After closer inspection, once I got home I found that around 5 teeth on the ring gear are pitted, for approximatly half of the tooth. Will this cause a whine in the rear?
Thanks |
Posted: Mon Oct 04, 2010 3:41 pm Post subject: |
Whine like crazy and eat itself up. _________________ A redline a day keeps the carbon away! |
Posted: Mon Oct 04, 2010 4:04 pm Post subject: |
Was it out of a blue Camaro? That was the only f-body in disassembly last weekend.
Sucks about the damage to the gears, cause a 3.73 9-bolt is kinda nice.  |
redlava Member
Posted: Mon Oct 04, 2010 5:02 pm Post subject: |
Came out of a blue firebird. It was pretty picked over the manual trans was already gone.
At least I still have the good 3.27 gears from my old rear still. So maybe I can put it together as a back up. I'll have to check out the cones over the weekened. |
Posted: Mon Oct 04, 2010 5:28 pm Post subject: |
| aaron_sK wrote: | Sucks about the damage to the gears, cause a 3.73 9-bolt is kinda nice.  |
Way more rare than a 3.70
redlava Member
Posted: Tue Oct 05, 2010 4:24 pm Post subject: |
I was looking at the gears more closely today and I think they will work fine as a back up. The pitting does not look nearly as deep as I had originally thought. Also a lot of the pits are isolated, from each other not allowing them to go very deep into the gear. Here is a picture of the pitting sorry for the bad quality (old camera).
Also this rear was missing the cover. Will rust be an issue here? How can I stop the rusting without obtaining a new cover? Right now I am just hand rotating it in oil every other day.
