Posted: Mon Dec 27, 2010 1:53 pm Post subject: A/C Compressor |
The pulley on my 89 froze up this morning. It made a terrible squeal as I pulled to light to stop, then the car stalled and wouldn't start up again. Might be time for a new battery too since I was able to jump start the car at home and overcome the drag of the frozen pulley, still squealing like mad. _________________ 92 Camaro
kurfbird Member
Posted: Mon Dec 27, 2010 3:08 pm Post subject: Compressor |
Al
I ahve a delete pully that I modified to repalce my compressor on my 92 bird 3.1 v6 let me know if interested.
Alos ahve a compressor from my 92 camaro if yhour interested in either _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
Posted: Mon Dec 27, 2010 3:21 pm Post subject: |
| Will either work for my 89 305? I know the compressor is on the other side of the motor than the V6. I want to keep A/C, but currently have no refrigerant in the system. If the delete pulley will work on the V8, I might go that route until I can charge the system, then replace the compressor when I do. |
kurfbird Member
Posted: Mon Dec 27, 2010 3:39 pm Post subject: Delete |
Ether will work being the compressor is the same for v6 or v8. The pully iteself was not modified. Just had to add some shims to make it work for a v6 car.
The pully was orginally for a v8 car _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Mon Dec 27, 2010 3:51 pm Post subject: |
Cool. I'm interested in the compressor then. Where can we meet? Bothell or Lynwood is easy enough for me, just a ferry ride and I have some trips on my pass to use up. _________________ 92 Camaro
kurfbird Member
Posted: Mon Dec 27, 2010 4:36 pm Post subject: Can Meet |
I can meet you on friday exit 183 164 street
Martha lake convenant church around 9:00 Am _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Mon Dec 27, 2010 5:56 pm Post subject: |
Sounds good. I'm sort of familiar with the area as I occasionally bowl with co-workers on 164th by I-5, just down the road a bit  |
kurfbird Member
Posted: Mon Dec 27, 2010 5:58 pm Post subject: Okay |
Okay that will work for me _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Mon Dec 27, 2010 8:02 pm Post subject: |
| PM me if anything changes. |
kurfbird Member
Posted: Mon Dec 27, 2010 8:22 pm Post subject: will let you know if anytrhig changes |
I will let you know if anytrhig changes _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
