VATS
PostPosted: Sun Dec 12, 2010 7:59 pm    Post subject: VATS Reply with quote
This morning before work I had a no start issue. Had to leave without trouble shooting. Just got back to the car I've had just a few minutes to look at it.
When the key is turned I get 12v to the starter enable relay in the drivers side kick panel. However, the diagram I pulled from alldata doesn't exactly match my relay.
Whoa that's big. So my relay has one large yellow wire that comes from the ignition switch and one large green one that I'm not sure where it goes. From what that diagram looks like, the blk/yel wire goes to the VATS module which provides the ground for the relay. Instead of trying to mess with VATS resistors and such and hoping the VATS module doesn't go tits up in the future, can I just split this wire off and ground it anywhere to get rid of VATS? Seem reasonable?
PostPosted: Sun Dec 12, 2010 8:20 pm    Post subject: Reply with quote
What kind of no start issue? Did it crank and not start or did it not crank at all?
PostPosted: Sun Dec 12, 2010 8:42 pm    Post subject: Reply with quote
Whoops. No crank, no start.
PostPosted: Sun Dec 12, 2010 9:16 pm    Post subject: Reply with quote
Welp, cooked myself some dinner and spliced the blk/yel to ground and now it fires off no questions asked. So it worked. Very Happy Why isn't this the preferred method of deleting VATS? Or is it supposed to interact with the factory ecm to kill something other than just starter enable?
PostPosted: Mon Dec 13, 2010 1:20 pm    Post subject: Reply with quote
My security light is on half the time and I can start the car with a chipped or non-chipped key. I should see how the PO disabled my VATS.
PostPosted: Mon Dec 13, 2010 1:48 pm    Post subject: Reply with quote
I thought it killed the injectors, or the pump, or both........ along with starter??
PostPosted: Mon Dec 13, 2010 2:33 pm    Post subject: Reply with quote
Shrug Never payed attention because mine always worked. And I've ripped out any factory ecm wiring now I guess my case may be different?
PostPosted: Mon Dec 13, 2010 3:14 pm    Post subject: Reply with quote
I had to argue with an Autozone employee the other day that my fan relay problem was the sensor not grounding, I guess multiple things work when you ground them Wink
-Donald
PostPosted: Mon Dec 13, 2010 5:42 pm    Post subject: Reply with quote
I'm on OBD2 also, but I made my vats work Very Happy It just goes to a different pcm now Cool
PostPosted: Mon Dec 13, 2010 5:47 pm    Post subject: Reply with quote
Do vats modules need to be programed or if I snag a replacement would I have to figure out what resistor key works with it?
PostPosted: Mon Dec 13, 2010 5:53 pm    Post subject: Reply with quote
I was just thinking. How did you wire up your OBD2? I figured you bypassed it anyway via the pcm. But if thats the case, then all the stock system was doing was your starter wire. No vats module will take care of that. I think what you did should work fine.
I used a vats bypass on a 94 3.4 system. They didnt care what the vats was.
:Edit: Also, whenever mine acts up, I blow some compressed air in the keyhole, wipe the key off (if its cold, I hold it in my mouth for a min). Then it goes back to working.
PostPosted: Mon Dec 13, 2010 6:49 pm    Post subject: Reply with quote
Correct, the obd2 pcm VATS setup was turned off.
Yeah, it seems to be working just fine since I took the vats module out of the equation (it's still in the car, just "unhooked") but I was thinking if I could replace/repair it, it would be a nice feature to keep functioning. I wonder if there is a way that the thirdgen vats module could with the obd2 pcm. Or, conversely a way to get the 4thgen vats module to work with the thirdgen column/key/ignition. Are they different? Hrmm...
What do you mean you used a vats bypass?
I initially tried two different keys (one that was a fresh cut spare) and got no results.
PostPosted: Tue Dec 14, 2010 3:48 am    Post subject: Reply with quote
on some of the early OBD2 pcm's they dont have a way to edit the pcm. So they hook up these bypass boxes that simulate the pulse needed to make the pcm work.
I hooked up my thirdgen vats box to my obd2 pcm. You have 2 choices on the theft system. One is "class2" the other is "pwm". I changed it to pwm and hooked up the vats box to the appropriate wire(yours will be diff then mine). And it all works.
How long did you wait before trying the keys? I forget what the exact time is you have to wait, but its stupid long.
PostPosted: Wed Dec 15, 2010 1:32 pm    Post subject: Reply with quote
The VATS looks for the right resistor key to be inserted. Once it finds it, it enables the starter relay and sends a 400hz (something like that) signal to the ECM. That is why on a stock ECM you have to use a PROM bypass. That or you bypass the relay and make a function generator to mimic the vats.
My LT1 I bypassed the relay and ran a PCM. BBC I run a custom prom.
PostPosted: Wed Dec 15, 2010 7:06 pm    Post subject: Reply with quote
It has a 4 minute timer, and it is stupid long.
PostPosted: Wed Dec 15, 2010 9:49 pm    Post subject: Reply with quote
I think when I get the front suspension rebuilt I'm going to look into repairing my vats system.
A few times before work, and a few times after. Laughing
