T-5 Inspection before retrofit?
rockstarr4
New Member
PostPosted: Sun Nov 21, 2010 9:30 pm    Post subject: T-5 Inspection before retrofit? Reply with quote
I just bought a 91 Firebird to take out the T-5 and replace the A700-R4 in my 84 Camaro. Once I have the T-5 pulled, does anyone have advice on physical inspections I should do on it before I re-install it? I just ordered a new Zoom MF clutch kit, but everything else will be a direct swap (I hope).
BluFbdy
PostPosted: Sun Nov 21, 2010 11:49 pm    Post subject: Reply with quote
going from auto to manual is never a direct fit. Just putting that out there its a lot of cutting and fitting, the only real inspection you can do without popping it open is gonna be spinning the input shaft as you go thru the gears, put it in neutral, spin the input, output should stay still, 1st, 2nd etc will spin thats about all you can do for it, you could open the drain pulg and check for metal shavings if you really wanted to
PostPosted: Mon Nov 22, 2010 6:23 am    Post subject: Reply with quote
Coulda fooled me. I only ever had to cut two holes. Maybe I was doing it wrong. Shrug
@ rockstar: Welcome to the crew, dude.
First off, the transmission you bought is set up for an electronic speedometer. Your '84 came with a cable-driven speedo, so that will have to be dealt with.
Do make sure to dump and check the fluid as was mentioned above. Metal is bad. Burnt is bad.
BluFbdy
PostPosted: Mon Nov 22, 2010 10:53 am    Post subject: Reply with quote
Cutting things generally means it doesn't fit and you need to do some modification lol that's all I meant, other than that its easy
PostPosted: Mon Nov 22, 2010 11:44 am    Post subject: Reply with quote
That trans fits fine. It's really only if you want to use the shifter and clutch pedal that you have to cut some stuff.
PostPosted: Mon Nov 22, 2010 1:34 pm    Post subject: Reply with quote
Laughing Indeed. If it's just for lookin' pretty, you can drop a T5 in place of a 700 without changing anything.
PostPosted: Mon Nov 22, 2010 2:22 pm    Post subject: Reply with quote
Or cut the two holes nicely just like the factory did.
PostPosted: Mon Nov 22, 2010 2:58 pm    Post subject: Reply with quote
I almost feel bad. It's dude's first thread/post and we're here flipping shizzle.
Welcome rockstarr4. Post up and intro thread in the back porch.
PostPosted: Mon Nov 22, 2010 4:15 pm    Post subject: Reply with quote
Make sure the input spins freely and doesn't wobble.
Same with the output. Check the splines on the input and the very tip where it rides on the pilot bushing in the back of the crankshaft.
rockstarr4
New Member
PostPosted: Mon Nov 22, 2010 6:04 pm    Post subject: Reply with quote
Thanks for all the advice (well maybe not all of it!). After the 3rd or 4th post I sort of figured you guys like to have fun with this stuff Smile
Any ideas on how to convert an electric speedo sender to manual output? Or should I just replace the speedo with a later model or aftermarket? Anybody with a source for a later model instrument cluster? I really don't want to spend a lot of $$
PostPosted: Tue Nov 23, 2010 10:27 am    Post subject: Reply with quote
You have to get an expensive conversion box. It's kind big because it has a motor to drive the cable. Have to hook it to power ground etc.
To convert the trans itself, you'd need a WC mainshaft for cable speedo, and a cable speedometer tailshaft. And a press, good snap ring pliars, etc to completely disassemble the transmission.
Or you do what I did and put Autometer gauges in LOL.
PostPosted: Tue Nov 23, 2010 3:36 pm    Post subject: Reply with quote
I'm with stupid
Took the cable drive 700 out of my car, dropped in an electric T-56 with Autometer gauges. Problems solved.
