Mountain Man's most wanted
PostPosted: Sun Nov 21, 2010 7:22 am    Post subject: Mountain Man's most wanted Reply with quote
Yeah, so I need some stuff for this project. Doesn't have to be fancy, just has to work. Wink
-Trans mount (doesn't have to be a good one, I just need it for mockup)
-LS1 driveshaft.
-Flat Camaro decklid (not drilled for spoiler).
-Brake booster that isn't all nasty and been sitting in the woods for years.
-The little trim panels for a Trans Am dashboard. Specifically the one that goes around the headlight switch, and the one that goes along the bottom with all the pushbuttons for the hatch, ect.
-I need the air diverter piece that came specifically from a car with a factory non-AC dashboard. Goes on the inside of the firewall, between the outer and inner airboxes.
There might be more later, as I think of it.
PostPosted: Sun Nov 21, 2010 10:06 am    Post subject: Reply with quote
You need another trans mount?
I may have the dash pieces. Will have to check the 'pile'.
PostPosted: Sun Nov 21, 2010 10:21 am    Post subject: Reply with quote
Which style dash pieces? There are three bird ones...
kurfbird
PostPosted: Sun Nov 21, 2010 12:18 pm    Post subject: Parts Reply with quote
ANswer your Pm. Let me know
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
PostPosted: Sun Nov 21, 2010 12:33 pm    Post subject: Reply with quote
I think GM sells brand new trans cross bars for about $10. Hard to beat that unless you get one free.
PostPosted: Sun Nov 21, 2010 1:23 pm    Post subject: Reply with quote
@ Mike: No, no, not the crossmember. I was wondering if someone had an old rubber mount I can use for mocking up. Ordering an Energy Suspension poly unit is on the list, but hasn't been done yet.
@ Ian: Dash came from the '88 GTA, so whatever that style is. I believe it ran from '85-'90, although I am not sure.
@ Bruce: You got PM, dude.
@ Jon: Except I did get one for free, thanks to our good friend Mike. Thumbs up
PostPosted: Sun Nov 21, 2010 1:28 pm    Post subject: Reply with quote
I think Mike left a booster/master cylinder combo here. If he didnt take it with him, then its here anyway. Might ask him bout it.
PostPosted: Sun Nov 21, 2010 1:33 pm    Post subject: Reply with quote
Jeezum crap! This whole car is going to be the GTA when I'm done with it. Laughing
PostPosted: Sun Nov 21, 2010 1:55 pm    Post subject: Reply with quote
At least that car is dead. I have half of Tony's GTA in my formula! LOL
PostPosted: Sun Nov 21, 2010 1:56 pm    Post subject: Reply with quote
If you can use the booster go for it.
The dash pieces would be from the same car.
PostPosted: Sun Nov 21, 2010 2:20 pm    Post subject: Reply with quote
If you guys can figure out whose house the booster is at, I'll take it. Don't need the master (would just add to shipping charge anyway).
PostPosted: Sun Nov 21, 2010 2:22 pm    Post subject: Reply with quote
Pretty sure its here.. I'll look though.. but its snowing at the moment and dont feel like going out there.
PostPosted: Sun Nov 21, 2010 3:16 pm    Post subject: Reply with quote
Why do you think I'm in here on the computer, and not out in the shop? Razz
PostPosted: Mon Nov 22, 2010 7:09 am    Post subject: Reply with quote
Need T5 hydraulics. I thought I had a set around here, but I must be going crazy or something. Rolling Eyes
Also need 85-90 rocker trim.
kurfbird
PostPosted: Mon Nov 22, 2010 7:27 pm    Post subject: rocker trim Reply with quote
rocker trim what side ??
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
PostPosted: Mon Nov 22, 2010 7:32 pm    Post subject: Reply with quote
Set.
kurfbird
PostPosted: Mon Nov 22, 2010 7:34 pm    Post subject: okay Reply with quote
I have both minus the doors peices for 60.00
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
PostPosted: Mon Nov 22, 2010 7:41 pm    Post subject: Reply with quote
Bruce, PM as we get closer to the weekend. We'll figure out a good time to meet up, and what all I'm buying.
BTW, I figured out the HVAC piece I was missing, so no worries there. I don't need that anymore.
PostPosted: Tue Nov 23, 2010 5:55 pm    Post subject: Reply with quote
I do have the booster assembly here.
PostPosted: Tue Nov 23, 2010 5:59 pm    Post subject: Reply with quote
Blame the Prior Owner Rolling Eyes
