		| Author | Message |
		| kidcamaro Member
				|  Posted: Fri Mar 11, 2005 4:16 pm    Post subject: what would i need to switch to put in a 350 |   |
				| just as the title says. what would i need? i know i would need a new ecm. would i need new injectors and stuff like that? |  |
		| Back to top |  |
		| JohnnyIROC-Z Member
 1995  Pontiac  Formula
				|  Posted: Fri Mar 11, 2005 9:55 pm    Post subject: |   |
				| What induction is your car? what Year? |  |
		| Back to top |  |
				|  Posted: Fri Mar 11, 2005 9:59 pm    Post subject: |   |
				| Excatly. We need to know everything about your car. What it has now, transmission, induction, etc. |  |
		| Back to top |  |
		| kidcamaro Member
				|  Posted: Fri Mar 11, 2005 11:51 pm    Post subject: |   |
				| 305/tpi/700r4 91 z28 no mods cept for k&n and flowmaster. |  |
		| Back to top |  |
				|  Posted: Sat Mar 12, 2005 12:21 am    Post subject: |   |
				|  	  | kidcamaro wrote: |  	  | 305/tpi/700r4 91 z28 no mods cept for k&n and flowmaster. |
 if you get a 350 roller block, long block (heads/cam/engine) all you need is a 350 Memcal/Eprom (computer chip $70@ gm parts direct), and a 350 knock sensor, and 22lb/hr injectors.
		| Back to top |  |
		| Wolffy Member
				|  Posted: Sat Mar 12, 2005 9:03 am    Post subject: |   |
				| Paul dont 350's use 24lb injectors stock ? or am i smoking something again
 i may be totally wrong, but i thought they used 24
		| Back to top |  |
		| JohnnyIROC-Z Member
				|  Posted: Sat Mar 12, 2005 12:10 pm    Post subject: |   |
				| You don't really need the computer though if you can find one might as well get it.  all you really need is 22lb/hr injectors and the knock sensor.  everything else is cake, And it's an easy swap. but you will need stay with the same year or newer 350, well actually 87 or newer because the difference in the head to intake manifold bolt style. So stick with an 87-92 350 and you're good to go. |  |
		| Back to top |  |
				|  Posted: Sat Mar 12, 2005 3:16 pm    Post subject: |   |
				|  	  | Wolfy's_88IrocZ28 wrote: |  	  | Paul dont 350's use 24lb injectors stock ? or am i smoking something again
 They use 22lb/hr stock. Rated at 41ish psi. 24lb injectors are Frod injectors and are rated at 39.5ish psi. Thus when you add more pressure like factory tpi, they act even bigger.
 Johnny, You need the 350 memcal. Period. You could run on 19lb/hr/305 bin like you did.... but it runs like crap and isn't good for it. You need to match tunes.
		| Back to top |  |
		| JohnnyIROC-Z Member
				|  Posted: Sat Mar 12, 2005 8:28 pm    Post subject: |   |
				| Mine didn't run like crap, It just didn't run to full potential, So it's not NEEDED, if he can't find one and needs that engine in then he can run without it, hell he can even run the 19lb injectors as long as he gets an AFPR and bumps it up to about 60 psi, of course that will burn out the injectors and the pump faster but it can be done, I would RECOMMEND getting a 350 chip and 22lb/hr injectors but it's not absolutely impertive is all im saying |  |
		| Back to top |  |
				|  Posted: Sat Mar 12, 2005 8:34 pm    Post subject: |   |
				|  	  | JohnnyIROC-Z wrote: |  	  | Mine didn't run like crap, It just didn't run to full potential, So it's not NEEDED, if he can't find one and needs that engine in then he can run without it, hell he can even run the 19lb injectors as long as he gets an AFPR and bumps it up to about 60 psi, of course that will burn out the injectors and the pump faster but it can be done, I would RECOMMEND getting a 350 chip and 22lb/hr injectors but it's not absolutely impertive is all im saying |
 Like I said though, 350 chip is $70 @ Gm Parts Direct. Forgot about having to supe the PSI up on the 19s yeah. Not a good idea either lol.
		| Back to top |  |
		| JohnnyIROC-Z Member
				|  Posted: Sat Mar 12, 2005 8:56 pm    Post subject: |   |
				| haha ya and DON'T do the homemade AFPR, doesn't work very well. |  |
		| Back to top |  |
