Posted: Sun Oct 03, 2010 4:29 pm Post subject: Misc. parts |
*Edited:
There is also some additional junk for the same low, low price of beer, but without any cool photographs ('cause it's all over at my Dad's ):
--12si alternators. Two of 'em. Forget how their clocked. Both seemed to work. One is v-belt, the other is narrow ribbed (like the late v-belt cars). That can be swapped easily though.
--Chebbie smallblock starter. Came off of my '87 L98 car. Worked fine, was pulled due to header clearance and transmission swap.
--90-92 dash, no gauges, no dashpad, no ecm, only partial harness. All other plastic, brackets, ect. are there.
--Edelbrock triangular air cleaner. Foamy kind, not the normal kind. Was run for all of about two days.
I will be at Ian's yuppie-vil... err... Bothell gathering, if that works better for anyone.
Posted: Sun Oct 03, 2010 5:10 pm Post subject: |
If you don't find anyone that wants it, you can always leave it in yuppieville.  _________________
Posted: Sun Oct 03, 2010 5:23 pm Post subject: |
| iansane wrote: | If you don't find anyone that wants it, you can always leave it in yuppieville.  |
Worst case scenario, I'll pull the hardware off it and throw it in with the beer and Monster cans. If nothing else it'll keep you from having it.  |
Posted: Sun Oct 03, 2010 8:46 pm Post subject: |
baleted
Posted: Sun Oct 03, 2010 9:07 pm Post subject: |
Bring the compressor and lines when you come up too.  |
Posted: Sun Oct 03, 2010 9:27 pm Post subject: |
| iansane wrote: | Bring the compressor and lines when you come up too.  |
Ian, you still want that cruise control unit as well?
Posted: Mon Oct 04, 2010 6:31 am Post subject: |
I need that.
Aaron, pretty please?
Clarification: Bellhousing and clutch fork. _________________ 84 Camaro Z28 - LS1/T56
Posted: Mon Oct 04, 2010 7:53 am Post subject: |
| Done deal. You want it now, or Friday? |
Posted: Mon Oct 04, 2010 12:37 pm Post subject: |
This weekend works for me. I don't need it immediately. _________________ 84 Camaro Z28 - LS1/T56
Posted: Mon Oct 04, 2010 4:40 pm Post subject: |
| aaron_sK wrote: | | iansane wrote: | Bring the compressor and lines when you come up too.  |
Ian, you still want that cruise control unit as well? |
Yes, yes I do. |
Posted: Mon Oct 04, 2010 4:56 pm Post subject: |
| Alrighty then. |
