Posted: Sun Jul 11, 2010 7:33 pm Post subject: Big parts post - mostly from '88 GTA |
Just sold the wheels. Bumping this back up as there are still some goodies left...
Complete 1988 LB9 (305 TPI) - ecm, harness, distributor, Bosch MAF - ran strong, normal chevy salute on startup - $500
TPIS Airfoil - $25
Comp Cams roller tip rockers, self-aligning, 1.5 ratio - $30 (might need a few pivot balls)
Manual transmission swap parts - Hydraulics, pedals, flywheel, clutch - $100
Gray plastics (back seat and rear hatch area) - Make offer
K&N filter for stock firebird air can, these are lifetime, I will clean and oil it - $15
140 MPH firebird speedo - make offer
I am sure I am forgetting a few odds and ends but most of the good stuff is listed above. Just ask.
SOLD:
GTA gold crosslace wheels, WS6 centercaps, lugs, lock, plastic lug caps
Electric rear hatch pulldown
Borg Warner 9 bolt rear, 3.27 (no PBR)
GTA seats, gray leather
GTA seats, gray cloth
Jamex strut tower brace
Serpentine belt setup
Gas tank, pump, hard lines
Radiator
Spohn adjustable panhard bar
Spohn adjustable LCAs
36 mm front sway bar
24 mm rear sway bar
Top down solutions steering brace (aka wonderbar)
T5 transmission
Hurst shifter
Dual electric fans
Full exhaust; headers, y, cat-back
Eibach Sportline lowering springs
Last edited by Schultzy89GTA on Mon Jul 25, 2011 11:56 am; edited 9 times in total |
Posted: Sun Jul 11, 2010 8:11 pm Post subject: Re: Big parts post - mostly from '88 GTA |
| Schultzy89GTA wrote: | Spohn adjustable panhard bar, poly/poly, black - $50
36 mm front sway bar - $30
24 mm rear sway bar - $25
Top down solutions steering brace (aka wonderbar) - $25 |
Mike, I was not previously aware of what suspension goodies you had under that GTA. I will gladly take such aforementioned goodies off your hands when I come down to pick up the rest of my stuff.
Posted: Mon Jul 12, 2010 10:54 am Post subject: |
Thanks.
List updated.
turbo_jimi Member
Posted: Mon Jul 12, 2010 12:07 pm Post subject: |
john/rs freak may be interested in the lowering springs. _________________
turbo_jimi Member
Posted: Mon Jul 12, 2010 12:40 pm Post subject: |
are the springs front or rear or both? _________________
Posted: Mon Jul 12, 2010 2:11 pm Post subject: |
Separate the catback? _________________
IROC-stangs Member
Posted: Mon Jul 12, 2010 2:52 pm Post subject: |
| like iansane said, would you sell headers/ypipe seprate? seriously considering if i can scrap $ together. |
Posted: Mon Jul 12, 2010 5:38 pm Post subject: |
Eibach springs are front and rear. Same ones I run on my GTA (also has two good 'donuts' for the rear which are included if yours are worn).
Exhaust - I am open to offers. I just listed as an entire system as I thought that might be attractive to folks.
Added a few other parts above.
Thanks for looking.
IROC-stangs Member
Posted: Mon Jul 12, 2010 8:10 pm Post subject: |
| stupid question, is the exhuast currently a full piece or is it in pieces? |
Posted: Mon Jul 12, 2010 9:26 pm Post subject: |
| headers and Y pipe all on their own. The cat back was taken off as a unit and is sitting that way in the barn. |
Posted: Tue Jul 13, 2010 4:12 am Post subject: |
Really wish I had money for the wheels  |
Darbbackwords New Member
Joined: 12 Mar 2010 Posts: 19 Location: Seattle/Whidbey
Posted: Tue Jul 13, 2010 11:15 am Post subject: |
| I might be interested in the whole exhaust system, or at least the headers and y pipe. Is the cat back a 3 inch system? |
Posted: Tue Jul 13, 2010 11:32 am Post subject: |
I believe that it is 3" but will have to check and get back to you.
Thanks,
Posted: Wed Jul 14, 2010 9:38 pm Post subject: |
T5 transmission and Hurst shifter sold. Thanks David. Good to see you again!
chevysquid Member
Joined: 28 Dec 2007 Posts: 72 Location: Coupeville, Washington
Posted: Thu Jul 15, 2010 9:06 am Post subject: |
Where are you at? I'm interested in those electric fans. _________________ 1986 IROC Z-28 |
Posted: Thu Jul 15, 2010 9:37 am Post subject: |
He's just into Oregon. If you're at the Coupeville on Whidbey, I can pick them up from Mike and bring them up on one of my whidbey weekends. I'll be down in OR next weekend. _________________ A redline a day keeps the carbon away! |
Posted: Thu Jul 15, 2010 9:40 am Post subject: |
| I plan on heading down this weekend for the exhaust. I should have room for more if anybody wants. |
Posted: Thu Jul 15, 2010 10:05 am Post subject: |
Brad,
Thanks. The fans and exhaust are in two diff locations. PM me with which day and about what time you are thinking for the exhaust and I will see if Brandon is available. Basically we have to coordinate with him but when I talked to him last night sounded like he would have some availability this weekend. Just need to agree on a window to be respectful of his time.
Chevysquid (sorry don't know your real name),
The fans are at my place SE of Portland. Sounds like Paul has graciously offered to pick them up when he is down here next so if you are interested let's make it happen! Thanks Paully for the offer!
chevysquid Member
Posted: Thu Jul 15, 2010 10:32 am Post subject: |
Paul, I would be eternally grateful if you could pick those up for me! How would we work it out? Paypal Schultzy or you the money? I don't need them any time quick, just a future mod thing. Have a clutch fan now.
Thanks guys,
Shawn _________________ 1986 IROC Z-28 |
Posted: Thu Jul 15, 2010 10:53 am Post subject: |
I sent you a PM Shawn. I will consider these sold then.
Thanks!
