Posted: Wed Jun 30, 2010 7:06 pm Post subject: It's amazing |
What you find when someone else has been "mechanicing". I've been putting a 6 cylinder from one truck into another for my mother in law. Anyway, I'd never heard it run, but my brother said it did. So I put it in there and get it fired up.. It had been sitting... awhile.. But I did get it going, on 4.. Did a compression check and cylinders 2 and 3 had no compression whatsoever. All the others were just fine. So then I back the rockers off on those 2 cylinders and apply air.. hmm it comes out the neighboring hole, but holds if I plug the neighboring hole. Head gasket! At least thats not too difficult or spendy. Got it pulled off tonight. Yup, 2" of gasket missing between those 2 cylinders. Looks to be a fresh head. Rear cylinder has had something foreign bouncing around in there previously. No sign of damage to the head, just the piston.
Now here's the kicker.. whoever changed the head.. Applied blue goo to both sides of the head gasket!!! Huge nono. Just makes the gasket slippery and slide out. They also applied enough that it had mostly closed alot of the water ports. No wonder they'd removed the thermostat.  |
Posted: Wed Jun 30, 2010 7:37 pm Post subject: |
I wonder what people who own motors I've previously owned think.  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Wed Jun 30, 2010 7:38 pm Post subject: |
| RSFreak wrote: | I wonder what people who own motors I've previously owned think.  |
Since when did you buy a car with a motor in it? |
Posted: Wed Jun 30, 2010 7:40 pm Post subject: |
| I'm kinda suprised they even used the gasket instead of just straight blue goo. I'm also wondering if perhaps it was a used head gasket and the blue stuff was supposed to "rejuvenate" it. Anyway, it made it fairly easy to clean off LOL |
| aaron_sK wrote: | | RSFreak wrote: | I wonder what people who own motors I've previously owned think.  |
There was some ghetto-rigged $hit on that motor we pulled out of your Camaro!  |
Posted: Wed Jun 30, 2010 7:42 pm Post subject: |
| chevymad wrote: | | I'm kinda suprised they even used the gasket instead of just straight blue goo. I'm also wondering if perhaps it was a used head gasket and the blue stuff was supposed to "rejuvenate" it. Anyway, it made it fairly easy to clean off LOL |
Hey now, sensor-safe silicone is the perfect fix for a minor gasket leak.
| RSFreak wrote: | There was some ghetto-rigged $hit on that motor we pulled out of your Camaro!  |
Yeah, but that "ghetto rigging" came from Chevy, and they called it the "LG4".  |
Posted: Thu Jul 01, 2010 9:20 pm Post subject: |
| aaron_sK wrote: | | chevymad wrote: | | I'm kinda suprised they even used the gasket instead of just straight blue goo. I'm also wondering if perhaps it was a used head gasket and the blue stuff was supposed to "rejuvenate" it. Anyway, it made it fairly easy to clean off LOL |
I was referring to the 'hillbilly engineering' which occured 'post assembly line'.  |
Posted: Thu Jul 01, 2010 9:35 pm Post subject: |
| RSFreak wrote: | | 'hillbilly engineering' |
Hey man, I don't even know what you're talking about. That plywood was there when I got here!
Speaking of which, you busy all this weekend? I got three days off, but a four-day paycheck.  |
Posted: Fri Jul 02, 2010 7:06 pm Post subject: |
I got 3 days off too, but I think I am totally booked. Next weekend is probably better for me, but I will let you know.  |
Posted: Sun Jul 04, 2010 1:05 pm Post subject: |
Next weekend is nhra drags at Pacific Raceways!!!!! _________________ A redline a day keeps the carbon away! |
Posted: Sun Jul 04, 2010 3:58 pm Post subject: |
RSFreak & aaron_sk --> you guys crack me up!  |
Posted: Mon Jul 05, 2010 8:19 pm Post subject: |
| QwkTrip wrote: | RSFreak & aaron_sk --> you guys crack me up!  |
We crack ourselves up too!  |
Posted: Mon Jul 05, 2010 8:31 pm Post subject: |
In fact I think too much crack is probably part of the overall problem.  |
Posted: Mon Jul 05, 2010 8:51 pm Post subject: |
| aaron_sK wrote: | In fact I think too much crack is probably part of the overall problem.  |
Luckily when we were parting out the GTA, Dawg wore suspendors.. Deb thanks him for that.  |
Posted: Mon Jul 05, 2010 8:52 pm Post subject: |
