Posted: Wed Jun 09, 2010 8:25 pm Post subject: Progress |
It doesn't seem like I've been busy but when you put it all together, sure.
Rear:
Tires were rubbing in the rear cause my spacers aren't thick enough. So I beat the inner fender in about a half inch with a BFH where the tire was rubbing. Surprisingly thin metal back there! Then I grabbed my friends fender roller and WENT TO TOWN. Actually didn't get to roll it too much cause that metal was thick. Still got it up enough now that now the rear does not rub what-so-ever anywhere when doing tight corners. I think with the a little more spacer I can run 315's in the rear no problem cause the 295's have lots of room.
Front:
Still am not finished with my big break kit so until that happens I completely boxed my a-arms in, pressed poly bushings, painted them black, and put them back together. Looks good! Then I installed my solid tie rod adjusters. What a huge difference all this made. Now I need bracing and lots of it. _________________ E30
Red Bird Member
1991 Pontiac Firebird
Posted: Wed Jun 09, 2010 11:06 pm Post subject: |
Looking good! So how does the car handle with the big block? does it push in the corners? get a chance to drift it yet? what kinda suspension set up do you have? _________________ 1991 Firebird L03 T-5 |
Posted: Thu Jun 10, 2010 9:30 pm Post subject: |
sweet work man! glad to see that beast making progress.
cameron7710 Member
Posted: Thu Jun 10, 2010 11:26 pm Post subject: |
sweet man that thing is so sick i defiantly need to check it out some time. iv been making alot of trips up your way lately i just wish i could take the camaro up there _________________
Posted: Fri Jun 11, 2010 7:06 pm Post subject: |
Oh wow. I forgot to mention that I hogged out the lower strut holes to allow me to move the strut further in on the tower cap. I think it must have worked, well, that and everything else. With 34mm front 24mm rear bar and 255 front 295 rear BFG KDW's, the car handles fairly nuetral around the roundabout by my house. If anything I might loosen the front bar cause the back end was stepping out just a little when nuetrally throttled.
Can anyone else comment if they slotted strut holes? Currently my strtu caps are all the way in so the struts basically touch a little in the allowed hole and I only have about a 0.5* camber.
@cameron, I'll be moving to eugene weekend so I might be a little closer to you. _________________ E30
Posted: Fri Jun 11, 2010 11:24 pm Post subject: |
| blue89 wrote: | | @cameron, I'll be moving to eugene weekend so I might be a little closer to you. |
Better bring that beast by my house in Bothell! I want to see it! |
Posted: Mon Jun 14, 2010 7:41 pm Post subject: |
Got any pics of the modified strut holes? I'm trying to imagine it but need a visual. _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Mon Jun 14, 2010 8:17 pm Post subject: |
| RSFreak wrote: | | Got any pics of the modified strut holes? I'm trying to imagine it but need a visual. |
Two giant bolts going through the strut and spindle. Equally giant nuts on the other side. Ring any bells, John?  |
