Boostd1 12sec Club
Joined: 28 Oct 2008 Posts: 437 Location: Thornton, Colorado
Posted: Thu Jun 03, 2010 8:08 pm Post subject: Operation Wire Tuck (Pic Heavy) |
Finally finished my wire tuck operation today...must say, looks significantly better without wires going over the TB/blower/valve cover! I took off all the factory loom, all the factory electrical tape and started from scratch, cutting out things like EVAP/EGR/Rear 02 Harness. I turned the injectors 180* to face inward so no injector clips show, extended the MAF/IAC/IAT/TPS for the LS1 TB (you dont see any wires from the front) Hid the MAP and the main Igntion Harness underneath the Coilpack Bracket, and tidy-ed up the rear a bit. Hit the spark plug wires with some greased lightning and steel wool, then put some tire shine on them (I know they'll get dusty over time) and they look brand new. Hit the valve covers with some brake clean, the strut towers with some too, and overall jsut cleaned up the bay a ton.
***NOTE: The PCM is sitting on top of an Icebox...I'm experimenting with one so bare with me [ ]***
Heres some pics. [ ]
Before -
After -
GM Performance Division Badge [ ]
Didn't leglect the back!
No sensors/plugs [&o]
Needs a bit more tucking...[:-]
Can see the MAP in this one...taken before relocated the MAP
[ ] Input is welcome! I need PRJ fuel rails to get rid of the rubber going over the blower (WBS rails stripped on me [8|])
Thanks! _________________ 1998 Grand Prix GT | 12.91 @ 103 - Sold/Retired
2008 Saturn Astra XR | Sold
2007 Infiniti G35x | Current DD |
Posted: Thu Jun 03, 2010 8:19 pm Post subject: Re: Operation Wire Tuck (Pic Heavy) |
| Boostd1 wrote: | | bare with me |
Dude, don't be weird.
Looks much better, although you may regret taping the harnesses vs. cleaning and/or replacing the looms. When I first did the wiring on the Monterey I got a wild hare and taped them. Then I realized I needed to reroute and change a few things, so I had to unwrap and retape. That pissed me off so bad I ditched the tape and just got some looms off of an old GM car. |
fiveoformula Member
Posted: Thu Jun 03, 2010 9:13 pm Post subject: |
Sweet dude, looks good in there, nice trick with the plug wires i'll keep that in mind. _________________
'88 FORMULA |
Posted: Thu Jun 03, 2010 9:33 pm Post subject: |
Man, looks great. I need to do that with my Megasquirt wiring on the Camaro, but I've been lazy. I'm more about how it runs than how it looks.
Posted: Thu Jun 03, 2010 11:32 pm Post subject: |
| It looks a lot better, next step, is to properly loom everything, instead of just electrical tape. But, the progress is good, and now you have something to aim for! |
Posted: Fri Jun 04, 2010 5:24 am Post subject: |
I don't mind the electrical tape for wrap. Lots of factory installations are just tape, convoluted tubing is bright and reflects more so it's more noticable.
At work Volvo has this awesome canvas eletrical tape. Durable and really dull black so it just fades away. _________________ A redline a day keeps the carbon away! |
Posted: Fri Jun 04, 2010 5:36 am Post subject: |
| Twilightoptics wrote: | | convoluted tubing is bright and reflects more so it's more noticable. |
Go for techflex stuff, it is bad arse. It is a little spendy, but not all that bad. |
Posted: Fri Jun 04, 2010 6:16 am Post subject: |
| Twilightoptics wrote: | | Lots of factory installations are just tape, |
Most factory "tape" is actually non-adhesive wire wrap. There only a little bit of stickum on the very end. If you try and replace it with standard electrical tape (especially the cheap dollar-a-roll kind), you'll end up with a goopy, tarry mess. |
Posted: Fri Jun 04, 2010 9:12 am Post subject: |
| aaron_sK wrote: | | Twilightoptics wrote: | | Lots of factory installations are just tape, |
I concur. It really sucks trying to undo something that has been electrical taped after even a month or two. It's gets goopy and messy. _________________ 84 Camaro Z28 - LS1/T56
Boostd1 12sec Club
Posted: Fri Jun 04, 2010 9:41 am Post subject: |
Thanks guys! Glad you all like it and thanks for the input. I may loom everything, but I do like the look of just electrical tape. It's hardly noticeable and loom just makes it big and bulky...and that's kind of what I was trying to get rid of.
Thanks everyone  _________________ 1998 Grand Prix GT | 12.91 @ 103 - Sold/Retired
Posted: Fri Jun 04, 2010 10:24 am Post subject: |
Looks awesome! I'm real picky about wiring and I need to get on my car sometime. I hate seeing wires. Waytek Wire (internet) and Grainger (local; do you have them over there?) both have some nice wire loom stuff that expands like those chinese finger cuffs. That with some heat shrink on the ends and it'll look pro no matter where it is.
Now that I was looking for a picture of it, I see the stuff I used from Grainger is techflex. So I second Dewey's suggestion!
Funny thing about that badge, I have one on my dash that I used to replace my 80s style "Performance Suspension" badge.  _________________
Posted: Fri Jun 04, 2010 4:43 pm Post subject: |
Another option is to buy the vinyl wire wrap. Looks like electrical tape, but no tar.
You can get it at places that sell stuff for restoring 60's Fords. Ford used it from the factory. |
IROCDave Member
Posted: Fri Jun 04, 2010 4:52 pm Post subject: |
Looks good man. I tried this about 15 years ago on my IROC and walked away pissed off. I also chased a possible bad connection for a couple of days. Then I remembered that when you unplug the batterey for an extended amount of time you have start the car and let it idle until it goes closed loop.
On this note, it is amazing how little wiring you see in todays engine compartments. This is the result of using multiple computers and much better emissions equipment. |
Posted: Fri Jun 04, 2010 5:40 pm Post subject: |
| New motors also have a lot of plastic wire covers and such. Look at an LSx when you take the coil covers and other platics off the motors. Then they aren't so good looking. |
Posted: Fri Jun 04, 2010 8:50 pm Post subject: |
That is real clean man. I have been threatening to clean up my wiring for a few years now
-Schultzy |
Richster Magic Fingers
Posted: Fri Jun 04, 2010 9:06 pm Post subject: |
Outstanding! That is just Clean...Clean! _________________
Boostd1 12sec Club
Posted: Mon Jun 07, 2010 9:19 pm Post subject: |
Thanks everybody! Yes, I have been procrastinating this for quite sometime now...just recently decided to do it on a random day off of work
I can imagine it would be alot harder to do on a V8 with alot more wires everywhere. 3800's are pretty simple motors with only a few wires  _________________ 1998 Grand Prix GT | 12.91 @ 103 - Sold/Retired
