Gauges
PostPosted: Mon May 10, 2010 9:13 pm    Post subject: Gauges Reply with quote
Any you guys have problems with 90-92 camaro gauges not working right??? my 91 the speedo not accurate, rpm not working, fuel, oil, and volt not working but the temp gauge works i have tried 3 different clusters in the car could it be a ground or wiring issue, or just a bad printed circuit board on the back?
