Tie rod question?
PostPosted: Sun May 02, 2010 2:19 pm    Post subject: Tie rod question? Reply with quote
So I noticed one of the reason my tires have been wearing funky was that the driver side was toed pretty significantly out. I assume from the accident. Are the drivers and passenger side tie rods equal length? Like, the drivers inner + adjuster + outer = passenger inner + adjuster + outer? My drivers side was almost a full inch longer than passenger. Shocked This isn't supposed to be exact but at least pretty straight for daily'ing until I get a real alignment.
PostPosted: Sun May 02, 2010 2:44 pm    Post subject: Reply with quote
You are correct. I just went out to check mine. Outers on both sides, approximately six inches from edge of adjuster to the center of the rod end. For grins, I checked the inners the same way and came up with about the same six inches.
PostPosted: Sun May 02, 2010 3:12 pm    Post subject: Reply with quote
You can't really have just one side toe'd in or out. Toe setting is just the difference from the rear to the front of the tire. Then you adjust the left and right sides to get the steering wheel straight. Left and right sides can be completely off with the steering wheel upside down, but the tires will wear fine if the total toe is correct.
PostPosted: Sun May 02, 2010 4:18 pm    Post subject: Reply with quote
Laughing Wow. That seems obvious if I think about it. I guess I should have said with the steering wheel straight + passenger side wheel straight the driver seems out of kilter. I pulled the driver side outer TRE in about 5 turns and I'll see if that eyeballs out better. I'm really tempted to setup a jig to measure actual toe. Have to level out the new garage though.
PostPosted: Sun May 02, 2010 6:23 pm    Post subject: Reply with quote
I have some toe plates I made using 1/4" hardboard. Works really well. Mine look really close to this but I made a cutout on the bottom so the tire bulge doesn't effect the plate.
PostPosted: Sun May 02, 2010 6:45 pm    Post subject: Reply with quote
So when you drive the wheel is crooked?
Toe settings will either wear both tires equally or make your steering wheel crooked. If you're wearing just one tire there's another setting out of wack.
PostPosted: Sun May 02, 2010 7:09 pm    Post subject: Reply with quote
I'm having a hard time imaging the tire bulge not affecting it. Have pictures so I can understand?
Up until today while driving down the freeway it would yank at all the ruts in the road a lot more than before. To the point that changing lanes was a turn hard against, let off, turn hard so I didn't overshoot as I crossed the ruts. With the wheel straight the passenger wheel was straight and the driver wheel kicked out and was wearing a ton more than the passenger.
Today I cranked the drivers side TRE inward about 5 threads and my wheel is a tiny bit crooked but it tracks SO much better. There is almost not tugging when changing lanes now. I just don't know if I went a bit too far or not? Both wheels looked parallel with the car now. (in the dim garage, I'm going to recheck tomorrow)
PostPosted: Sun May 02, 2010 7:31 pm    Post subject: Reply with quote
I can see how that wasn't too clear. The bottom middle (horizontally) of the plate is cutout cause the tire bulges there. The middle (vertically) of the tire bulge is consistent enough that I use it to align with. You can also use the string trick. Worked really well with my sentra! Just wrap a string around all 4 tires. Google it.
We've got an old school setup at work. Couple of turntables so theres no friction on the tires. Then a stick with pointers that stick up about mid tire. Then I simply rub a line down the middle of the tire. (jack rig up, hold something pointed against tire, spin tire to leave mark) Put the stick on the backside of the tires and set both pointers on the lines.. Move stick to front of tires and you can see where your toe is. A tape measure can do it, but usually part of the car is in the way to get a measurement halfway up the tire.
PostPosted: Mon May 03, 2010 9:36 pm    Post subject: Reply with quote
Does anyone know if there is an upgrade to the centerlink and tie rod's beside going end links? I'm stiffening my a-arms and noticed my tie rods, idler, and steering box bend and flex an unexceptable amount when you push on the wheels with the steering wheel locked. I have solid tie rod adjusters to put on but I don't see that helping the entire problem.
PostPosted: Mon May 03, 2010 10:06 pm    Post subject: Reply with quote
I don't know of any beefier units but is there really that much deflection during forward motion? Even most "racecars" I see only use rod ends...
PostPosted: Tue May 04, 2010 6:45 am    Post subject: Reply with quote
I had the wheel fully drooped when I did it so the tie rods had the best leverage on the centerlink. Just seemed that with a little push in you could see the center link being pushed up cause the arms were deflecting up. I'll try it again tonight with the tie rods level as they would be under normal driving conditions. Still makes me wonder.
PostPosted: Tue May 04, 2010 7:02 am    Post subject: Reply with quote
There is always deflection. The question is how much, and in which direction.
PostPosted: Tue May 04, 2010 7:29 am    Post subject: Reply with quote
That is true. I can see that under normal conditions that the road won't have nearly the leverage I did to make the linkage deflect. I'll install my solid couplers and ignore what I saw, for now.
Ian, have you done any steering upgrades to your front yet?
PostPosted: Tue May 04, 2010 7:34 am    Post subject: Reply with quote
Zip tie a video camera down there, and post up the results for us all to see!
Really, at normal ride height, the tie rod and center-link are decently close to parallel, compared to when they are at full droop. Also, the outside tire is the one handling most of the force, which will be under even more compression during cornering.
I really have no idea how much deflection there actually is, I would be really interested to see any actual test you do.
--John
PostPosted: Tue May 04, 2010 8:45 am    Post subject: Reply with quote
Shocked Do eeeet.
Just solid TRE adjusters. I've currently been on an aero kick. Working on underbelly/ghetto diffuser/splitter. Very Happy
I see you mentioned beefing up your control arms. Is the deflection seen in flexing A-arms more than what you would see from new poly bushings? I mean, would you see better gains by going to a control arm with rod ends or something of the like? (although mucho more expensive-o Sad )
PostPosted: Tue May 04, 2010 3:40 pm    Post subject: Reply with quote
On my LT1 car I put in poly bushings and then welded extra metal to stiffen it up. Basically just closed in the bottom of the a-arm. Weither or not it actually did anything, I dunno. Sure does make me feel better.
And it's much cheaper than the fancy tubular arms.
PostPosted: Tue May 04, 2010 7:21 pm    Post subject: Reply with quote
Shocked Do eeeet.
oooh, you have my attention now. Start a new thread with some detailed pictures and specs.
