how do i bypass VATS
Goto page 1, 2, 3, 4, 5, 6, 7  Next
91camaro_rs
PostPosted: Tue Apr 20, 2010 8:44 pm    Post subject: how do i bypass VATS Reply with quote
what is the easiest way to bypass VATS? how do i know how much resistance to use if i dont know what the number was for the orignial key, for that computer
PostPosted: Tue Apr 20, 2010 8:50 pm    Post subject: Reply with quote
If you have the original key you can measure the resistance and put the appropriate resistor inline.
http://tpiparts.net/vehicle_anti_theft_system__vats_/
91camaro_rs
PostPosted: Tue Apr 20, 2010 8:52 pm    Post subject: Reply with quote
original key as in the key that went to the ECM that i put in my car?
i only have the key that went to the v6 that i pulled out, too bad that computer wouldnt work
i did notice that the computer from the v6 also ended in 730 like the v8 one, could i use the v6 computer with the v8 chip?? would that even bypass VATS?
PostPosted: Tue Apr 20, 2010 8:54 pm    Post subject: Reply with quote
The ECM doesn't care what value resistance the key has. What matters is that the key resistance matches the VATS module, which is where you would bypass it with the appropriate value resistor(s).
When the right value is read by the VATS module, it sends a signal to the ECM.
91camaro_rs
PostPosted: Tue Apr 20, 2010 8:59 pm    Post subject: Reply with quote
so do i even need to bypass it then, considering i didnt do anything to the VATS module and i have the keys for my car, is it just something else not making it start?
PostPosted: Tue Apr 20, 2010 9:02 pm    Post subject: Reply with quote
What does it do? Does the fuel pump prime when you turn the key? If it does, chances are it's not VATS.
91camaro_rs
PostPosted: Tue Apr 20, 2010 9:31 pm    Post subject: Reply with quote
when i turn the key all it does is the lights and guages turn on, thats about it, i cant hear the fuel pump or anything
PostPosted: Tue Apr 20, 2010 9:43 pm    Post subject: Reply with quote
It might be worth a try to bypass the module. It seems to be a common problem for the wires in the ignition lock cylinder to break, then VATS keeps the car from starting.
I haven't done it before, so I couldn't tell you where it is other than under the driver side dash. Find a resistor or group of resistors that total the resistance of your key pellet and install per the following link.
http://vats.likeabigdog.com/
PostPosted: Wed Apr 21, 2010 6:17 am    Post subject: Reply with quote
Do you have a blinky security light when you try to start the car? Does it crank and not fire, or does it not even crank at all?
Your original VATS module is still there and connected to the ECU, so your original key should still work fine. Other people here are more VATS experts than me, but if I was you I would check for fuel pump prime by having someone listen at the bottom of the tank and check for spark as well. I'd only suspect VATS if I knew for sure that the symptoms of no-start matched what VATS does when it locks down the car. I do not know what VATS does to prevent start, but I'm sure someone else here does. Razz
If it helps (probly not) the V8 ECU is from a '91 as is the V6 ECU.
91camaro_rs
PostPosted: Wed Apr 21, 2010 7:20 am    Post subject: Reply with quote
security light does blink when i turn the key, but nothing else happens other than the guages move a little, i cant hear the fuel pump and the motor doesnt even crank...
could i have a bad ground? maybe i wired it completely wrong, cause idk how it SHOULD be wired.
PostPosted: Wed Apr 21, 2010 7:55 am    Post subject: Reply with quote
Sounds like a VATS problem to me. Especially because of the blinking security light. I'll have to let someone more knowledgeable step in because I don't really know how VATS works, and it should be fine with your VATS module and key that you already have from the V6 ECU.
If you had used the MAF setup it wouldn't have VATS at all... Razz Too late now.
PostPosted: Wed Apr 21, 2010 11:00 am    Post subject: Reply with quote
qué?
PostPosted: Wed Apr 21, 2010 12:19 pm    Post subject: Reply with quote
The vats light does light up for a second when you start the car even if its working.
As Alphius said. The vats mod was what was in your car before the re-wire, then it still matches your car and is fine aslong as you hooked up the ecm correctly. All of that should have been simple plugs... But I would check that circuit over again. Maybe have changed what position it was in the plug between years????
When vats acts up, the car will not even crank... I dont remember about the fuel pump. It takes 5min to "reset". I have had it act up before and get it to work after warming the key up. Try blowing out your ignition switch also.
Make sure you have the purple wire on the correct side of the starter. Wink (my selonid has 2 little lugs, plus the big one)
Double check grounds, I have missed the ones on the back of the heads, and the intake several times Doh! Also dont know if you dx'd the battery ground to block, but check it also.
91camaro_rs
PostPosted: Wed Apr 21, 2010 12:23 pm    Post subject: Reply with quote
i have no idea where which ground is supposed to go...i know my battery was grounded to the frame when i had the v6. the VATS isnt in the wiring harness at all is it?
i dont know where the vats thing is but im pretty sure i didnt mess with it
PostPosted: Wed Apr 21, 2010 12:29 pm    Post subject: Reply with quote
My battery ground goes to my block, on both the v6 and v8. Then you should have a ground strap from the back of the block to the firewall(head or bellhousing). Also a short small pigtal from the battery lug, to the body.
The vats module itself is somewhere way deep in the dash, but it connects to the ecm via one of the quick connects under the pass side of the dash. Then has a short run to the ecm itself. So more then likely, you played with the wiring. IIRC its a blue wire.
I didnt follow your orginal swap that well. I assume your car is a 91, what year harness/ecm did you drop in?
:edit: I can help you a little more in about an hour after I get home and can pull my dash panel n snap pics if you need
91camaro_rs
PostPosted: Wed Apr 21, 2010 1:08 pm    Post subject: Reply with quote
if you could take pics that would be awesome, cause i am so lost at this point
so as of now i have my positive battery cable running to the starter and the little cable that is connected grounds at the body
im not sure where i should have the negative battery cable ground at
only thing i have plugged into the alternators little post is the wiring for the fuel pump
i dont even know where the ground is supposed to go to the starter...i made a wire and connected it to the frame...
and i do have a ground strap going from the firewall to the block
i took a carbed 305 from an 85 Z28, put a 86? T/A TPI unit on it, computer came out of a 91 and wiring came out of a GTA not sure on year, he said he was gonna use it for a LSx project
PostPosted: Wed Apr 21, 2010 1:23 pm    Post subject: Reply with quote
Schultzy89GTA wrote:
qué?
I gave him a Speed Density ECU and a MAF ECU to choose between for the swap. The MAF setup was from an '87, so no VATS.
91RSVert:
He's got an '85 305 with an '87 TPI and a '91 SD ECM. I don't know about the wiring harness, but it's a SD harness, and his car is originally a v6 '91.
91camaro_rs:
Three things must be connected in some way for your grounds to work. Battery, engine and body. AFAIK Battery ground connects to motor or frame, and motor connects to body somewhere. As long as all three of those things are connected in some way to each other your major grounds should be OK.I believe 91RSVert is correct, the VATS wire entering the ECU comes from the driver's side and it is dark blue. That's the fuel enable wire.
Here's the wiring diagram from AllData:
Looks like the wiring may be different depending on which motor was in the car, look at the top right where it shows the ECU and says "For VIN: blablabla and For other VIN: blablabla" It looks like one ECU was pin C1 and one was pin C3. Let me know if you need any more wiring diagrams or anything, I can get any you need.
Don't give up hope! Looks like we're pretty darn close man! Very Happy
PostPosted: Wed Apr 21, 2010 1:34 pm    Post subject: Reply with quote
ok, were getting you confused.
First, which ECM are you using since you were given 2?
Grounds. You will have a bunch of little hoops within the harness, all need to be grounded somewhere, aslong as its steel. As far as I'm concerned, your battery cable needs to be to the block. But if you have a good solid strap to the motor, should be good as you have it(I doubt you messed with it anyway).
Pos. The big one should be to the starter as you said. With it, should be some orange and red wires that have little white "fuses" that go to the harness. All should be on the big lug.
Starter. Your purple wire should be on a lug all by itself. My starter has 2, and I had it on the wrong one at first.
Alt, you have the plug. Then you have a fat red wire, iirc, it should feed down to the starter???
Fixing to go snap some pics for you. But my harness will be different since its a 2002 harness.
PostPosted: Wed Apr 21, 2010 1:40 pm    Post subject: Reply with quote
Listen to 91RSVert, he's more succinct than me. All his wiring advice there is accurate. He posted while I was writing mine. Wink But I got the VATS diagram, so if that's the problem it's in my post. Razz VATS being screwed up will make the security light blink multiple times.
PostPosted: Wed Apr 21, 2010 1:50 pm    Post subject: Reply with quote
gracias Very Happy
Page 1 of 7
