Power Stroke gets a new sound
PostPosted: Sat Apr 17, 2010 7:15 pm    Post subject: Power Stroke gets a new sound Reply with quote
I installed a Banks Monster exhaust on my 2000 7.3L today. This is a 4" turbo back. The previous owner didn't think a muffler was necessary and had removed it. I've been driving like that for about 4 years and got tired of the loud burble on the freeway. The Banks exhaust still has a burble on the freeway but it is more muted. Around town the Banks is a LOT more quiet outside the truck, but I'm almost certain that it's louder inside the truck. Not the outcome I was wanting. But then again, it's still a whole lot more quiet than my Duramax was with a MBRP 4" turbo back. Didn't notice any difference in engine power. I guess you've got to have a chip to see the benefit of the exhaust. I've got to say, though, that the 5" polished exhaust tip looks mighty fine on my truck. Very Happy
PostPosted: Sat Apr 17, 2010 8:29 pm    Post subject: Reply with quote
What type of muffler does the Banks kit run? Is it a straight-shot, or louvered?
PostPosted: Sun Apr 18, 2010 8:00 am    Post subject: Reply with quote
It is a straight tube thru the center of the muffler from end to end that is the same size as the exhaust tubing. The tube has a bunch of perforations and is surrounded by some type of sound dampening. The outer case is fairly large, and a whole lot bigger than the MBRP on my Duramax. That MBRP could barely pass off as a muffler. It was hardly any bigger than the pipes going in and out.
PostPosted: Sun Apr 18, 2010 12:28 pm    Post subject: Reply with quote
Sounds like I installed the same exhaust on my brother in law's 2000 7.3L. Came with a new turbo exhaust exhaust housing thing without the backpressure flap, stainless 4" pipe, magna flow type muffler, and a 5" tip. Installation wasn't bad, took me a while up toward the engine though. He's happy with it so I'm happy.
PostPosted: Sun Apr 18, 2010 7:12 pm    Post subject: Reply with quote
Cool. Presumably they include that same muffler with the exhaust system in their turbo kits, so I'll get some decent sound out of the IDI. Very Happy
PostPosted: Sun Apr 18, 2010 7:40 pm    Post subject: Reply with quote
Once you turbo it you don't need no stinkin muffler.
Jon, mufflers are for old men. Laughing
Back when I was logging our pickups had to meet certain criteria to go in the woods, one of those was a muffler on a NA diesel , but could run straight pipe when turboed. Sparks don't get past a turbo.
PostPosted: Mon Apr 19, 2010 3:23 pm    Post subject: Reply with quote
I'll take the muffler over being cool any day. At least my ears don't hurt now when I drive next to a concrete barrier. Wink
PostPosted: Mon Apr 19, 2010 4:58 pm    Post subject: Reply with quote
That's what made me want a muffler on the bird. I'm ditching the side exit asap.
PostPosted: Mon Apr 19, 2010 5:14 pm    Post subject: Reply with quote
True duals?
PostPosted: Mon Apr 19, 2010 5:40 pm    Post subject: Reply with quote
True duals?
No thanks. Too complicated for me. Y pipe is fine for my needs. Smile
PostPosted: Mon Apr 19, 2010 5:42 pm    Post subject: Reply with quote
I still got a Magnaflow catback in the garage if you want to go that route.
PostPosted: Mon Apr 19, 2010 5:52 pm    Post subject: Reply with quote
Reeeaaalllyy? I tossed out my old mag catback thinking I was going to like this setup. What condition is it in?
PostPosted: Mon Apr 19, 2010 6:09 pm    Post subject: Reply with quote
Used, but still shiny. Very Happy
It's actually an older 4th-gen setup. The previous owner had it on an '89 IROC. He welded up new brackets, and a flange so it will bolt to a stock cat, but you won't need to worry about that. Razz
The pieces have never been welded together. It came with band-style clamps, no horseshoe BS.
