posi conversion
91camaro_rs
PostPosted: Fri Apr 09, 2010 9:25 pm    Post subject: posi conversion Reply with quote
im pickin up a posi rear tomorrow,
how much will the speedo be off if the rear has 373 and the ones i have now are 323?
PostPosted: Fri Apr 09, 2010 9:32 pm    Post subject: Reply with quote
tciauto.com
racing calculator
91camaro_rs
PostPosted: Sat Apr 10, 2010 7:24 am    Post subject: Reply with quote
ok, so if the posi really is 3.73 then my speedo will be 8 mph slow... so how do i find out exactly what the gear ratio is? and what all do i need to make the speedo accurate?
91camaro_rs
PostPosted: Sat Apr 10, 2010 7:44 am    Post subject: Reply with quote
anyone have a link to the chart that tells the number of teeth you need for each gear ratio? i remember seeing it once but i cant find it again Laughing
redlava
PostPosted: Sat Apr 10, 2010 8:22 am    Post subject: Reply with quote
http://www.transmissioncenter.net/speedometer_calibration_______va.htm
If you see something on the website that is not in-stock, just call. They do not update there site often.
BTW you need a new housing to hold the new plastic gear, the stock one will not work.
91camaro_rs
PostPosted: Sat Apr 10, 2010 4:09 pm    Post subject: Reply with quote
got the posi home and cleaned up the outiside of it and took the brakes and stuff off, everything was rusted together, and i figured out it has 3.08 gears...and my car has 3.23 now so i want to stick with the 3.23 and that way i dont need a new speedo gear, i can just swap tailhousings. cause i gonna just put the posi unit in the rear end i have now
PostPosted: Sat Apr 10, 2010 8:04 pm    Post subject: Reply with quote
The posi carrier with the 3.08 gears is a 2-series carrier. Your 3.23 gears will not work on it, being as they are 3-series gears.
3.08 and lower gears are 2-series.
3.23 and higher are 3-series.
So you can either buy gears for that 2-series posi carrier, or run the 3.08 gears. You're sure it's a posi carrier?
Oh yeah, and that rear if it is pre-'89ish has 26-spline axles, while yours since it is newer has 28-spline axles, so you'd have to use matching axles to your carrier.
91camaro_rs
PostPosted: Sat Apr 10, 2010 11:34 pm    Post subject: Reply with quote
posi came out of a 87 iroc, 5 speed
so if i keep the 3.08's in there how many teeth is the speedo gear have that i will need to make sure the speedo is right?
91camaro_rs
PostPosted: Sat Apr 10, 2010 11:53 pm    Post subject: Reply with quote
so i tried using the calculator and i rember the color of the gear on my transmission, its the greenish yellow one (19 tooth drive gear)
so in my car now i have a 19 tooth drive gear and according to the calculations with a 26.8 wheel (is that the right wheel height?) i have a 46 tooth driven gear, and it says with 3.08 gears and a 19 tooth drive gear i will need a 44 tooth driven gear to make the speedo correct...does that sound right?
PostPosted: Sun Apr 11, 2010 11:09 am    Post subject: Reply with quote
Tire size for a stock IROC wheel is 245/50R16. If you do the math, the stock total diameter is 25.6 inches for a thirdgen Camaro.
Go see what color the drive gear is on your V8 700R4. With a 19-tooth drive and 3.23 gear ratio (what you have now) you would need a 48-tooth driven gear, which does not exist. Stepping down to 3.08 makes it need a 46-tooth driven gear, which also does not exist. The biggest driven gear you can get is a 45-tooth, which if you have the 19 tooth drive with 3.08 gears will make your speedometer off by roughly 2-3%.
91camaro_rs
PostPosted: Sun Apr 11, 2010 1:02 pm    Post subject: Reply with quote
wow that was dumb of me to think i was gonna use the V6 tailhousing lol
the gear on the V8 is red which is the 17 tooth gear,
using 25.6 inches for the tire height and 3.08 for the ratio i get a 41 tooth gear
bought the gear and the new housing
