Posted: Sun Apr 04, 2010 10:49 am Post subject: Wet seats, the hunt continues |
Not long ago, I had the antenna on the roof of my purple 92 resealed as it was leaking past the weather donut. I thought it was working for a while, but with this last bout of heavy rain, I found another wet seat, rather a seat back.
I got some things torn apart, and when I was the trim from the back of the headliner, I felt a drip on my arm. Couldn't find anything, so I brought the hose over and started a stream flowing over the hatch seal. About a minute later, I see a few drips oozing from under the weather strip near the driver side hinge. Time for some sealant under the rubber or a new piece all together. I'll try the sealant first as that's the less expensive way to go. _________________ 92 Camaro
Posted: Sun Apr 04, 2010 11:43 am Post subject: |
| The hinges themselves can leak as well. I think thats where mine currently leaks actually. |
Posted: Sun Apr 04, 2010 12:44 pm Post subject: |
I found a notch in the ridge that the seal fits over right at the spot where the leak is. I filled the whole top edge of weatherstrip with RTV (the only stuff I had) and laid some down along the inside edge of the seam it fits over. Hopefully it will work for a while.
turbo_jimi Member
Posted: Sun Apr 04, 2010 12:47 pm Post subject: |
found a puddle in my rear drivers side yesterday too...luckily, my fender protector was there and i was able to soak it up with a towel...too close to good weather for me to seal the t-tops. man, i need my own garage  _________________
flea Member
Posted: Sun Apr 04, 2010 4:58 pm Post subject: |
I still have two problem areas.
One is that the trunk well fills with water, probably two inches deep. Its entering from the drivers side plastic compartment thing, but I don't know where the water itself is coming from.
The other is the passenger door panel gets usually 10 or 12 drops of water on the carpet on that door panel. The carpet at the passengers feet is always dry.
Still, much better than it was. T tops can be so frustrating. _________________ Killing mailboxes since 2009 |
Posted: Mon Apr 05, 2010 8:22 pm Post subject: |
| flea wrote: | I still have two problem areas.
Still, much better than it was. T tops can be so frustrating. |
Spoiler corner seal? Metal-to-glass seal on the hatch? Both places my Sport Coupe leaked like crazy.
I'm lost on the other leak. _________________ 84 Camaro Z28 - LS1/T56
Posted: Mon Apr 05, 2010 8:26 pm Post subject: |
| Alphius wrote: | | flea wrote: | I still have two problem areas.
I'm lost on the other leak. |
My driver door in the red one does the same thing. Very intermittent. I'm replacing the hinge pins and bushings before I go looking for this one though, maybe it's just seal fitment - the seals are new. |
Richster Magic Fingers
Posted: Wed Apr 07, 2010 2:12 pm Post subject: |
Bummer Al, I hope you find the leak man, water can be such a pain to find the origin, but it sounds like you have a good lead on it!
Here's to a great seal! _________________
Posted: Wed Apr 07, 2010 3:18 pm Post subject: |
| turbo_jimi wrote: | found a puddle in my rear drivers side yesterday too...luckily, my fender protector was there and i was able to soak it up with a towel...too close to good weather for me to seal the t-tops. man, i need my own garage  |
You have your own garage, but your wife's mini van lives there!  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Wed Apr 07, 2010 9:26 pm Post subject: |
| Richster wrote: | Bummer Al, I hope you find the leak man, water can be such a pain to find the origin, but it sounds like you have a good lead on it!
Here's to a great seal! |
I found where it's leaking. Maybe I fixed it, but to be sure, it's going to need a metal or plastic piece epoxied/JB Welded in place to close the hole. The tech that installed my first satellite antenna decided to cut a "V" in the pinch weld to pass the cable through the weather strip. That antenna has been gone a long time and the adhesive holding the weatherstrip in place finally wore out. I'll get a permanent fix on there when the weather dries out  |
Posted: Wed Apr 07, 2010 9:40 pm Post subject: |
Sounds like a good plan! Ouch on the cutting but sounds like a fix is on the horizon, way good! _________________
