TurdGen1989 Member
Posted: Wed Mar 10, 2010 5:25 pm Post subject: |
are you willing to part with the center caps off the maroon one? and the lug nuts also? _________________ Phil.
GMC High Sierra
flea Member
Posted: Wed Mar 10, 2010 9:52 pm Post subject: |
anyone give me an honest answer as to the PITA level of swapping the rear seats from the split rear to solid? If its as easy as a straight swap then I would be interested in the rear seats pictured, mine are something close to being completely FUBAR and since Im tearing out the interior for new carpet anyway, well, might as well consider new 25 year old seats. _________________ Killing mailboxes since 2009 |
kurfbird Member
Posted: Wed Mar 10, 2010 9:57 pm Post subject: seat swap |
Pretty easy. You will ahve to add the slit seat bracket to your floor. I drilled out the welds then rivited back to the floor in the proper location. Or you can weld it in place
This was one of my first conversions. pretty easy _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
IROC-stangs Member
Posted: Wed Mar 10, 2010 9:59 pm Post subject: |
| evermind about the hatch or the hood/wheels the hatch wont work on my friends camaro. sorry. i wouldnt mind the floormats but i dont wanna have you go out of your way just to bring those down. |
flea Member
Posted: Wed Mar 10, 2010 10:34 pm Post subject: Re: seat swap |
| kurfbird wrote: | Pretty easy. You will ahve to add the slit seat bracket to your floor. I drilled out the welds then rivited back to the floor in the proper location. Or you can weld it in place
This was one of my first conversions. pretty easy |
It sounds like you are describing converting from solid to split, I currently have split seats the picture looks like a solid, I might be mistaken about that though. So do I need to add the brackets, or will I need to remove them. I dont care one way or the other if the seats are solid or split, I just want good, clean unstained seats if they can be switched easily. Sounds like they can be. _________________ Killing mailboxes since 2009 |
kurfbird Member
Posted: Wed Mar 10, 2010 10:42 pm Post subject: Re: seat swap |
| flea wrote: | | kurfbird wrote: | Pretty easy. You will ahve to add the slit seat bracket to your floor. I drilled out the welds then rivited back to the floor in the proper location. Or you can weld it in place
It sounds like you are describing converting from solid to split, I currently have split seats the picture looks like a solid, I might be mistaken about that though. So do I need to add the brackets, or will I need to remove them. I dont care one way or the other if the seats are solid or split, I just want good, clean unstained seats if they can be switched easily. Sounds like they can be. |
Sorry I read it the wrong way. Tired.
Yes its pretty easy to just drill out the welds and removed the bracket. _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Wed Mar 10, 2010 10:48 pm Post subject: |
Do you even need to remove the bracket? I have a horrible memory but I seem to recall my room mate used to have an 85 TA that we put 4thgen solid back rear seats when his originally came with split. Just bolted each side down? Worth a shot... _________________
91camaro_rs Member
Posted: Wed Mar 10, 2010 11:09 pm Post subject: |
| IROC-stangs wrote: | | 91camaro_rs wrote: | @IROC-stangs someone called me about the hood, if he doesnt buy it you can have it for $100, its in great shape. the z28 wheels on the maroon car im looking to get $150 they come with good tires. and hatch id say $50 or so, floor mats $5, i will not ship this stuff cause its all so darn huge, but i will deliver, idk where in oregon you are, but if you pay me gas ill bring the stuff down
@Greg, seats under seat covers have the normal tears, not in the best shape ill get pics today
@Al, car has no motor..... so cant really remove sensors from engine block, unless thats what all that wiring and stuff in the engine bay is
gettin more pics today |
the hood or wheels arent something that i need i just though they would be nice to fix up expecialy the hood to repaint but i dont have the money right now. i'll talk to my friend that needs the hatch and see if he wants it and i'll probaly take the floor mats if my friend wants the hatch so you dont have to come all the way down here.? are there rear mats? and what condition is the hatch and the mats? thanks. i'm in tigard. |
i have a set of actual camaro floor mats that are in perfect condition, if you just want the mats i can ship them to you....
and yes i do have the horn button for the steering wheel,
i took a ton of the black interior out of the maroon car today, most of it i will use in my car so that means i will have a lot of red interior stuff for sale soon
and switching from split to solid rear seats is pretty easy, just a bolt on each side i believe, so i would assume you would have to remove the split seat bracket
and i want to sell the lugs and center caps along with the rims _________________
91camaro_rs Member
Posted: Wed Mar 10, 2010 11:12 pm Post subject: |
@Dan Johnson the dash pad in the blue car is perfect, i looked at it today, no cracks or anything, they are going for about $160 on ebay..idk if thats high or not but i would sell it for $100 its in really good shape _________________
GREG DAVIDSON Member
Posted: Wed Mar 10, 2010 11:21 pm Post subject: |
| let me know what you have left of the black int when you get done, i mainly want seats but i may have found a set closer to home i'll let you know |
91camaro_rs Member
Posted: Wed Mar 10, 2010 11:28 pm Post subject: |
the seats that you see in the pics, passenger side and rear are in good shape, rear are pretty clean, and driver side has tears, im pretty sure im using the black seats in the blue car, and that means my red seats will be for sale _________________
Posted: Wed Mar 10, 2010 11:38 pm Post subject: |
ok nevermind then  |
91camaro_rs Member
Posted: Wed Mar 10, 2010 11:56 pm Post subject: |
ok, so after i completely strip the cars this weekend, im going to go through all the parts, each and everyone and write down what it is so i have a list of everything that way its easier to see what i have, and so i know what i have  _________________
flea Member
Posted: Thu Mar 11, 2010 6:38 am Post subject: |
Let me know what you want for the back seats, I might have to take those off your hands. _________________ Killing mailboxes since 2009 |
91camaro_rs Member
Posted: Thu Mar 11, 2010 12:41 pm Post subject: |
how does $60 sound for the seats? _________________
chevysquid Member
Joined: 28 Dec 2007 Posts: 72 Location: Coupeville, Washington
Posted: Thu Mar 11, 2010 2:00 pm Post subject: |
Would you be interested in trading your perfect dash pad for my double adjustable panhard bar? Or the springs, either one. _________________ 1986 IROC Z-28 |
91camaro_rs Member
Posted: Thu Mar 11, 2010 4:29 pm Post subject: |
i might be interested in trading for the panhard bar, but i do still need money for TPI system, fuel pump and some other things, but if i make enough off the other stuff then i will be interested in trading _________________
IROC-stangs Member
Posted: Thu Mar 11, 2010 4:52 pm Post subject: |
| 91camaro_rs wrote: | | IROC-stangs wrote: | | 91camaro_rs wrote: | @IROC-stangs someone called me about the hood, if he doesnt buy it you can have it for $100, its in great shape. the z28 wheels on the maroon car im looking to get $150 they come with good tires. and hatch id say $50 or so, floor mats $5, i will not ship this stuff cause its all so darn huge, but i will deliver, idk where in oregon you are, but if you pay me gas ill bring the stuff down
and i want to sell the lugs and center caps along with the rims |
what do the mats look like if you dont mind me asking and how much do you want? also im not sure how to send money never done it. |
chevysquid Member
Posted: Thu Mar 11, 2010 5:24 pm Post subject: |
| 91camaro_rs wrote: | | i might be interested in trading for the panhard bar, but i do still need money for TPI system, fuel pump and some other things, but if i make enough off the other stuff then i will be interested in trading |
cool, let me know. _________________ 1986 IROC Z-28 |
Darbbackwords New Member
Joined: 12 Mar 2010 Posts: 19 Location: Seattle/Whidbey
Posted: Fri Mar 12, 2010 12:17 am Post subject: |
If the floor mats are still there when I get the mirror, I will take them. (the rubber Chevy ones pictured right?) I may also be willing to do some delivery of parts for people in Seattle/Whidbey area, but I don't plan on doing more then one run.
On another note, I saw the early black door panels and might be interested. (haven't ever seen them in person and don't know what you want for them.) |
