Posted: Mon Mar 01, 2010 8:15 pm Post subject: New look for headlights |
I replaced my broken housing today, the lens was cracked since the second day after I installed the lights. While I was at it, I replaced the #194 light bulbs for the halos with white LEDs. Much better look, instead of looking like dim yellow lights, I have a bright white halo.
Side by side after installing the LEDs behind the reflector...
 _________________ 92 Camaro
Posted: Mon Mar 01, 2010 8:18 pm Post subject: |
| That neon look is much better Al. |
Posted: Mon Mar 01, 2010 8:32 pm Post subject: |
Looks even better with all 4. A little camera movement here, but the look is there...
Posted: Mon Mar 01, 2010 8:58 pm Post subject: |
Very nice!
-Schultzy |
Posted: Mon Mar 01, 2010 9:30 pm Post subject: |
Sweet! Where did you get them? _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Tue Mar 02, 2010 7:36 am Post subject: |
Do you have dual beam housings for your outer and inner lights Al? If so, how do you have them set up? All 4 on low beams and high beams, or only the outer two on lows? _________________ 84 Camaro Z28 - LS1/T56
Posted: Tue Mar 02, 2010 7:45 am Post subject: |
They are all 4 H4 bulbs (hi-lo). the outer pair work normally as high and low beam and the inner pair only as high beam. I jumpered the high anbd low spades together on the inner pair to use both as a very bright high beam. It takes a little larger fuse and the housing might not like the heat, but high beams aren't on for a very long time anyway. _________________ 92 Camaro
Posted: Tue Mar 02, 2010 7:53 am Post subject: |
| Al Hasse wrote: | | They are all 4 H4 bulbs (hi-lo). the outer pair work normally as high and low beam and the inner pair only as high beam. I jumpered the high anbd low spades together on the inner pair to use both as a very bright high beam. It takes a little larger fuse and the housing might not like the heat, but high beams aren't on for a very long time anyway. |
I need new headlights and I wasn't liking the thought of more sealed beams. I've done H4/H1 conversions before, and I already have a dedicated headlight circuit with relays etc. on my car.
Your way is how I would do it. Thanks for the info.
EDIT: What about these? They're glass lenses and composite housings for just a little more money. With bulbs as well.
http://www.amazon.com/82-92-CHEVY-CAMARO-HEADLIGHT-CONVERSION/dp/B001NFVI1G/ref=pd_sbs_auto_2 _________________ 84 Camaro Z28 - LS1/T56
Posted: Tue Mar 02, 2010 12:06 pm Post subject: |
| I'm not familiar with those, but they look like the same style that Paul runs on his Camaro. Quite a bit more expensive than his e-Bay lights too. |
Posted: Tue Mar 02, 2010 1:09 pm Post subject: |
I'm wanting to do the diamond headlights with the h1/h4. Just waiting on a light to blow so I have an excuse to spend money  |
Posted: Tue Mar 02, 2010 1:39 pm Post subject: |
3 of mine are cracked/chipped and get wet inside. I've been waiting to blow one as well, but they have all just kept working for over 2 years!
Finally time to upgrade, even if my stupid headlights won't break already. I'm sure I'll be amazed by headlights that don't suck.
I can't find any glass lens headlight housings on eBay for cheaper than the $100 for 4 with bulbs on Amazon. Plastic ones, including those Pilot brand Al has are there though. There is an overabundance of round projector style housings, but I hate the look of those. _________________ 84 Camaro Z28 - LS1/T56
Posted: Tue Mar 02, 2010 1:57 pm Post subject: |
| FWIW, the Pilots I have do have glass lenses, however, the housings are plastic as are the reflectors. |
Posted: Tue Mar 02, 2010 2:02 pm Post subject: |
| Al Hasse wrote: | | FWIW, the Pilots I have do have glass lenses, however, the housings are plastic as are the reflectors. |
Thanks, didn't know that.  _________________ 84 Camaro Z28 - LS1/T56
