Posted: Sun Feb 21, 2010 1:22 am Post subject: She lives!!!! Almost... |
My T/A will almost be ready for the dyno! Almost... But we did make great progress today finishing the electrical stuff and making sure all the accessories worked. All thats left to do is drain and refill all fluids, attach spark plug wires, get a new powersteering pully and belt, and procure a new coolant temp sensor. The gas (half a tank) has been in the tank for at least 2 years so a can of Seafoam is going in and probably some "fresh" gas as well. It also has two flat tires so we'll have to deal with that as well. All in all I think James and I made great progress towards getting her back on the street!  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Sun Feb 21, 2010 8:47 am Post subject: |
John, does Seafoam help nasty gas?
I've got some stuff that's been in the Monterey since last summer that smells kinda fishy (forgot to put Sta-Bil in it ). It's like half a tank though, so I'd hate to siphon it. |
Posted: Sun Feb 21, 2010 9:42 am Post subject: |
Sweeeeeet! I take it you got the PS bracket all set up? I have a spare thirdgen pulley if you need it. You guys working on it today? I could just stop by. _________________
Leejo2005 Member
Posted: Sun Feb 21, 2010 10:58 am Post subject: |
| Quote: | | I've got some stuff that's been in the Monterey since last summer that smells kinda fishy (forgot to put Sta-Bil in it Doh!). It's like half a tank though, so I'd hate to siphon it. |
The last time I was deployed I left my mustang parked for somewhere around 9 months and it fired right up. I'd just make sure to get new fuel asap. Also, condensation could have formed inside and have collected in the tank, especially since it isn't full all the way. If you're at all worried about it I wouldn't chance sucking up some water. |
Posted: Sun Feb 21, 2010 12:31 pm Post subject: |
So.... While cleaning/organizing my shed I found the directions to the March bracket.  |
Posted: Sun Feb 21, 2010 12:52 pm Post subject: |
| iansane wrote: | So.... While cleaning/organizing my shed I found the directions to the March bracket.  |
It isn't fully installed 'cause I still need the new pully and don't have a puller. I could use those instructions! Also is your pully a 5 rib? If so I could use that to.
Aaron, yes Seafoam will "recondition" old gas.  |
Posted: Sun Feb 21, 2010 12:57 pm Post subject: |
Well I've got both the pulley and the puller.
I'm almost 100% sure it's a six rib because the March dual crank pulley was six rib, right? And the factory belt for my car was a six rib. I don't know about the pre-88 serp setups though... |
Posted: Sun Feb 21, 2010 1:03 pm Post subject: |
The alt is a 5 rib so I got the stock 5 rib belt for it, but it seemed fine on the 6 rib crank pully. The serp style water pump pully has me a little nervous, but you ran it like that, right?
BTW Ian, we aren't working on the car today but James will probably be there (hes enjoying some freedom while his family is out of town) if you wanted to drop that stuff off. |
Posted: Mon Feb 22, 2010 6:28 am Post subject: |
Thanks for the pulley Ian! That will put us one step closer to getting her going!  |
Posted: Mon Feb 22, 2010 8:47 am Post subject: |
No problem. Like I said to James, anything to get another bird on the road. |
Posted: Mon Feb 22, 2010 5:25 pm Post subject: |
Did you check out the engine?  |
Posted: Mon Feb 22, 2010 5:39 pm Post subject: |
| Yeah! It looked great! TPI looked right at home. |
Posted: Mon Feb 22, 2010 8:25 pm Post subject: |
| iansane wrote: | | Yeah! It looked great! TPI looked right at home. |
It should, it had TPI from the factory! Of course now it sports your old '91 305 and a TPI cobbled together from the original '86 parts and that one you sold me that I think we determined was equal parts '87 and '91.  |
