thud on take off
PostPosted: Sat Feb 06, 2010 9:12 am    Post subject: thud on take off Reply with quote
well today the camaro started to make a thud sound when i take off hard at all if i take off slowly its fine but the harder i take off the louder the thud is. it sounds like its coming from the rear end but i put it in reverse and did it, and it sounded/felt like it was coming from the trans. the thing is fine other than take off. i can punch the gas as hard as i can when moving and its fine only when i am at a complete stopped then take off. all i can think off is maybe somthing with the drive shaft or maybe a trans mount? so let me know what you guys think
PostPosted: Sat Feb 06, 2010 9:49 am    Post subject: Reply with quote
Check your front torque arm mount. The bolt in mine backed out a bit last weekend and it made the same type of noise. The mount is on the transmission tail shaft.
Trans mount could do it too. A 5-speed shifter would lift through the floor with a loose/broken mount, but auto would just make noise as the trans hits the underside on acceleration.
PostPosted: Sat Feb 06, 2010 10:00 am    Post subject: Reply with quote
ya when i put it in reverse it sounded like the trans bashed into the underside of the car
PostPosted: Sat Feb 06, 2010 10:07 am    Post subject: Reply with quote
Trans mount.
PostPosted: Sat Feb 06, 2010 10:26 am    Post subject: Reply with quote
rjmcgee wrote:
Trans mount.
Wisdom. Cheap and easy. Don't let it go on too long.
Mine clunked when I ripped my front torque arm mount out of the transmission case, but I don't think you have the power to make that happen. In that case it was the torque arm banging the bottom of the car.
PostPosted: Sat Feb 06, 2010 10:49 am    Post subject: Reply with quote
Get the Energy Suspension part. They don't crap out like the rubbers do. Schmucks used to carry them and price match Summit, no idea if they still do after the buyout.
PostPosted: Sat Feb 06, 2010 11:29 am    Post subject: Reply with quote
rjmcgee wrote:
Trans mount.
ya thats what i thinking. im going to go take a look under the car to make sure
ya i dont think a stock lo3 is gona have the power to do that lol
ya for sure
PostPosted: Sat Feb 06, 2010 11:53 am    Post subject: Reply with quote
ok i just went and looked at it and at first i was confused becauses everything looked fine (trans mount, torque bar mount,all the suspension and everything looked great. but then the i noticed the most obvious thing ever. the nut the holds the trans mount to the cross bar was completly missing Doh! Embarassed well at least it will be super cheap and easy to fix lol
PostPosted: Sat Feb 06, 2010 12:17 pm    Post subject: Reply with quote
Is the trans mount stock? I'd be really surprised if you jacked up on the trans and it completely separated from the xmember... If you're under there might as well change it.
PostPosted: Sat Feb 06, 2010 6:26 pm    Post subject: Reply with quote
ok nut replaced works like new now Very Happy
d00012
PostPosted: Sat Feb 06, 2010 7:08 pm    Post subject: Reply with quote
Thread Jacked Laughing
Mine started making noise in the rear after replacing the fuel pump. Only on the passenger side. I shook the rear wheel and you can hear it wobbling around somewhere inside...could I have possibly not tightened something all the way?
PostPosted: Sat Feb 06, 2010 11:16 pm    Post subject: Reply with quote
Get your panhard stuff bolted down?
Leejo2005
PostPosted: Sun Feb 07, 2010 7:41 am    Post subject: Reply with quote
If it is the trans mount fixing it soon would be the best. I put mine off on my Z28 back in high school too long and the floor pan had some nice dings in it afterwords.
d00012
PostPosted: Sun Feb 07, 2010 5:03 pm    Post subject: Reply with quote
Haha, not all the way. I need to jack it up and tighten it down. Checked it today and it was moving around in there...about 1-3mm of play.
PostPosted: Sun Feb 07, 2010 5:39 pm    Post subject: Reply with quote
I could imagine you might hog out the holes by letting that stuff be loose like that. I'd jump on it and tighten those down asap.
d00012
PostPosted: Sun Feb 07, 2010 5:56 pm    Post subject: Reply with quote
Just did. Still loose, but not as bad, was loose before, the car just needs new suspension.
