		| Author | Message |
		| Leejo2005 Member
				|  Posted: Fri Jan 22, 2010 4:00 am    Post subject: Engine progress. |   |
				| Today I finally made some progress putting together my new motor for the bird. Got the bottom end put together minus the oil pump. Just a few things and the short block is complete and I can start assembling the heads and put them on. |  |
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Fri Jan 22, 2010 6:59 am    Post subject: |   |
				| Another Ford blue engine. There must be something to this...  |  |
		| Back to top |  |
 1989  Pontiac  GTA
				|  Posted: Fri Jan 22, 2010 7:12 am    Post subject: |   |
				| Good deal. Keep us posted on progress!
		| Back to top |  |
		| IROCDave Member
				|  Posted: Fri Jan 22, 2010 6:08 pm    Post subject: |   |
				| Are you concerned that the paint in the lifter valley might come off over time and cause problems? |  |
		| Back to top |  |
		| Leejo2005 Member
				|  Posted: Fri Jan 22, 2010 9:07 pm    Post subject: |   |
				| Heh, I know Ford blue, but it's pretty and as much as I love orange-red it would look tacky under the hood of my car. As far as the paint peeling off I haven't had problems in the past when doing it but who knows I haven't experienced everything by any means. |  |
		| Back to top |  |
		| RSFreak The other "John"
 1989  Chevrolet  Camaro RS
				|  Posted: Sat Jan 23, 2010 11:21 am    Post subject: |   |
				|  	  | IROCDave wrote: |  	  | Are you concerned that the paint in the lifter valley might come off over time and cause problems? |
 I've heard that painting the lifter valley actually helps oil drain back ('cause of the smoothness?).
		| Back to top |  |
		| chevymad Master B
 1987  Pontiac  Formula
				|  Posted: Sat Jan 23, 2010 11:28 am    Post subject: |   |
				| Usually you want to use Glyptol though to paint the inside of a motor. As long as the stuff he's using sticks it will work though. Would make me nervous. I don't even use the glyptol stuff. |  |
		| Back to top |  |
		| alloy T56 Elitist
				|  Posted: Sat Jan 23, 2010 1:19 pm    Post subject: |   |
				| I found some electric motor varnish from granger that I used on my block.Much cheaper than glyptal. Come in a spray can.
 In the past I've also used  rustoleum and it held up for over 5 years til I tossed a rod in my little 302 motor.
 Ronald Reagan:  "Most of us wonder if our lives made any difference.  Marines don't have that problem."
		| Back to top |  |
				|  Posted: Sat Jan 23, 2010 3:00 pm    Post subject: |   |
				| Bigger pan solves the need for a slick coating. Best way IMHO  if a bigger pan isn't used is to smooth the casting flash itself.
 It's what we do at work if someone has their heart set on it.  Coatings require the bock to be rediculously clean. Not worth it unless you roadrace.
		| Back to top |  |
		| Leejo2005 Member
				|  Posted: Sat Jan 23, 2010 4:38 pm    Post subject: |   |
				| Being that this is just my lil ol 305 I'm not too worried about drying out my oil pan, to be honest I just painted it to keep it from rusting when I got it back from the machine shop and because it looks neat. I did, however, dremel some burrs off the block where the oil runs back down, since it was easy enough to do. |  |
		| Back to top |  |
		| Leejo2005 Member
				|  Posted: Sat Jan 23, 2010 8:44 pm    Post subject: |   |
				| el conando is mas macho |  |
		| Back to top |  |
		| Leejo2005 Member
				|  Posted: Mon Jan 25, 2010 3:16 am    Post subject: |   |
				| As of this evening... |  |
		| Back to top |  |
		| Leejo2005 Member
				|  Posted: Fri Jan 29, 2010 5:33 pm    Post subject: |   |
				| I ordered a new fuel tank and straps for it this morning. Hopefully my leave request goes through so when we get back I can have a whole week off to get this swap done. |  |
		| Back to top |  |
		| QwkTrip 11sec Club
 1989  Pontiac  Firebird
				|  Posted: Fri Jan 29, 2010 6:08 pm    Post subject: |   |
				| Where did you buy it from and how much did it cost?
 I might have to get a new tank, too.
		| Back to top |  |
		| DBL_TKE Member
 1991  Chevrolet  Camaro Z/28
				|  Posted: Fri Jan 29, 2010 6:10 pm    Post subject: |   |
				| Looking good, will it be ready for dyno? _________________
		| Back to top |  |
		| Leejo2005 Member
				|  Posted: Sat Jan 30, 2010 6:24 am    Post subject: |   |
				| I bought my tank from http://www.autopartswarehouse.com . They sell two tanks for the fuel injected models, one 14 and one 15 gallon. As far as I can tell they both will fit, they use the same straps and fuel sending unit. Mine was $263 with straps after everything was said and done. I was going to get one from GasTanks.com since I had purchased one for my 1967 Plymouth a few years back from them, but this place offered a better price so we'll see. |  |
		| Back to top |  |
