Posted: Wed Dec 30, 2009 4:35 pm Post subject: EGR vacuum solenoid |
An obsolete part that my car is missing. It's for an '87 LB9 engine. Need one fairly quick. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Sat Jan 02, 2010 1:38 am Post subject: |
I guess it's not as important anymore as on TGO, somebody said that they successfully used one from a '95 Cadillac DeVille 4.9. Hope he's right! _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Sat Jan 02, 2010 1:42 am Post subject: |
I'm not sure if the one from a TBI car will work, but I have all my EGR stuff sitting somewhere in my garage.
--John |
Posted: Sat Jan 02, 2010 1:44 am Post subject: |
They are different part numbers. I'll do a little research on that and if the Cadillac doesn't work I'll try yours. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
