redlava Member
Posted: Wed Nov 25, 2009 11:27 pm Post subject: Adjust the governor, WOW |
| I just adjusted the governor from 4500 to about 6200 rpm. I must say the car is a different animal. Can't believe I waited this long to do this. The car is much faster, even allowing it to brake the tires loose on the shifts now. Kinda curious though if the cam's operating range is up to 5800rpm. Does this mean that max power most likely occurs at/near 5800 rpm and you can rev past this? The engine seems to run great through the shifts/ up through the rpm range (6200rpm). However I don't want to cause damage for a few extra rpms. Should I just try an another adjustment on the governor? |
Posted: Wed Nov 25, 2009 11:33 pm Post subject: |
| What valvetrain? Redline and cam peak are two very different things. |
redlava Member
redlava Member
Posted: Thu Nov 26, 2009 10:12 am Post subject: |
| I forgot to mention that I was mainly worried about the bottom end. The pistons, rods and crank are cast. Would it be benificial to upgrade to arp bolts for the rods and main caps? |
redlava Member
Posted: Fri Nov 27, 2009 5:23 pm Post subject: |
| Well I adjusted the shift points down to 5800 from 6200. I'm just gonna leave it there, thought I would give an update. |
Posted: Fri Nov 27, 2009 5:26 pm Post subject: |
| redlava wrote: | | I forgot to mention that I was mainly worried about the bottom end. The pistons, rods and crank are cast. Would it be benificial to upgrade to arp bolts for the rods and main caps? |
Rod bolts tend to be the SBC stock rod weekness. The rods are forged. :O) Just not a quality aftermarket forging or H beam.
ARP bolts are the best. To install the bolts you'll have to have the rods out of the engine, and have the caps resized with the new bolts. If you just shoved them in, the caps will never align properly and cause pre-mature engine failure.
Same goes for the main bolts. Putting ARP studs in requires a line bore.
I've got stock rods/crank myself in a 2 bolt block and beat on it pretty good. _________________ A redline a day keeps the carbon away! |
