sorry not 3rd gen related
batcave
PostPosted: Tue Nov 03, 2009 7:41 pm    Post subject: sorry not 3rd gen related Reply with quote
anyone have any suggestions on a 96 blazer 4x4 4.3 pulling engine out how does one seperate engine from trans no cover for torque converter bolts or should i just pull it all out in one anyone ever done one of these do i have to pull the core support out no real clearance for pulling all out any suggestions would be helpfull thanks
PostPosted: Tue Nov 03, 2009 7:43 pm    Post subject: Reply with quote
The cover is the solid aluminum place on the bottom of the bellhousing. It has 3 15mm headed bolts on each side, and there may be 2 brace rods attached to the bottom of it.
PostPosted: Tue Nov 03, 2009 8:11 pm    Post subject: Reply with quote
Took the engine and trans out of my S10 (first gen) without removing the core support, but I had to get the truck up pretty high to do it. Going back in, I got smart and pulled the support.
If you don't need the trans, don't pull it. Get the bellhousing bolts out, take the hood off,, throw a jack under the trans. Then just yank the motor up a little, out towards the front, and then straight up.
batcave
PostPosted: Tue Nov 03, 2009 9:48 pm    Post subject: Reply with quote
the only way to possibly get torque conveter bolts out is threw the starter these are the worst blazers to work on it looks like threw the core suport i go
PostPosted: Tue Nov 03, 2009 10:03 pm    Post subject: Reply with quote
I've changed motors in these things.. and transmissions.. that cover comes off.. then you can get to the bolts. You might have to pull the exhaust Y pipe to get the torque convertor cover off though.
PostPosted: Wed Nov 04, 2009 7:12 am    Post subject: Reply with quote
I'm with stupid
Just did a '95 Jimmy myself.
Pull the radiator, not the core support.
A Load Leveler will be your friend.
If you can't get that cover off, remove the starter and access the bolts from that hole.
PostPosted: Wed Nov 04, 2009 7:37 am    Post subject: Reply with quote
Cover would still have to come off.. you can't pull flexplate through the starter hole!! Wink
PostPosted: Wed Nov 04, 2009 7:38 am    Post subject: Reply with quote
Hehe yeah.
PostPosted: Wed Nov 04, 2009 7:46 am    Post subject: Reply with quote
It would be kinda fun to see somebody try it, though. Laughing
PostPosted: Wed Nov 04, 2009 7:49 am    Post subject: Reply with quote
I took a 00 2wd 4l60e out in the junk yard. IIRC I just undid the bellhousing, exhaust, cross member, d shaft, and the braces and just slid the trans back. Leaving the flex and torque on the motor.
But that was early last summer (like 15mo ago).
Being that is 4x4, I would leave the trans in, and just try and pull the motor.
