Failed Emissions lol (UPDATE...PASSED!!!)
Boostd1
PostPosted: Wed Oct 07, 2009 5:49 pm    Post subject: Failed Emissions lol (UPDATE...PASSED!!!) Reply with quote
Well, everything passed with flying colors...hell they even passed me on my EVAP system (Which I don't have Question )
HC was half the limit...
CO was significantly lower than the limit...
Passed OBD Codes (Thank you HPTuners!!! Laughing )
Only thing was NOx output...over 4 times the limit!!! My guess is that this reading is high because the combustion temps are too high...I am running stock plugs on the L32 (Iridiums) and no EGR (I know that would fix that, but I'm determined to pass with no EVAP and no EGR!!!) I think AL104's will extract enough heat from the combustion chamber to pass the test...thoughts?
Remember, this is all on E85 with no EGR or EVAP Twisted Evil
2008 Saturn Astra XR | Sold
PostPosted: Wed Oct 07, 2009 6:10 pm    Post subject: Reply with quote
Have no idea there, wouldn't you want a colder burning plug? I do know that last time I passed emissions with my EGR bypassed. lol I would have failed with one more hydrocarbon, no joke, 219/220. lol
'88 FORMULA
Boostd1
PostPosted: Wed Oct 07, 2009 6:18 pm    Post subject: Reply with quote
Haha thats funny...
Yeah thats my idea, Iridiums burn all kinds f hot, and AL104's burn WAY cooler. Like 3-4 steps I think.
PostPosted: Wed Oct 07, 2009 6:23 pm    Post subject: Reply with quote
Cool hopefully that works... How are the emission laws over there?
Boostd1
PostPosted: Wed Oct 07, 2009 6:29 pm    Post subject: Reply with quote
Umm..
Allowed HC is 1.5000
CO limit is 15.0000
NOx limit is 1.50000
PostPosted: Wed Oct 07, 2009 8:30 pm    Post subject: Reply with quote
I hate you Lame
PostPosted: Thu Oct 08, 2009 4:07 am    Post subject: Reply with quote
Since your running boost, I would think you would want to put similar plugs in to that of the L67?
PostPosted: Thu Oct 08, 2009 11:48 am    Post subject: Reply with quote
Boostd1 wrote:
Umm..
CO limit is 15.0000
High elevation FTW!!
PostPosted: Thu Oct 08, 2009 5:24 pm    Post subject: Reply with quote
Boostd1 wrote:
Umm..
CO limit is 15.0000
Wow, what unit of measure are using? Those numbers are completely different than over here.
Boostd1
PostPosted: Thu Oct 08, 2009 6:14 pm    Post subject: Reply with quote
Yeah its weird though, I am running the plugs that came with the stock L32 motor (basically a newer L67) and I guess they burn WAY too hot for emissions Confused
PostPosted: Thu Oct 08, 2009 6:40 pm    Post subject: Reply with quote
oh, I thought the L32 was the nonboosted 3800.
Boostd1
PostPosted: Fri Oct 09, 2009 8:08 pm    Post subject: Reply with quote
Series II Engines
L36 - Naturally Aspirated 3800 V6
L67 - Supercharged 3800 V6
Series III Engines
L26 - Naturally Aspirated 3800 V6
L32 - Supercharged 3800 V6
Just for clarity lol
Anyway, going to swap out the plugs this Sunday...hope it does the trick Embarassed
Boostd1
PostPosted: Thu Oct 15, 2009 9:02 pm    Post subject: Reply with quote
Update! Found a vacuum leak. Caused LTFT's and STFT's to be maxxed out causing a super duper lean condition. Car should pass with flying colors now Smile
PostPosted: Thu Oct 15, 2009 10:22 pm    Post subject: Reply with quote
Dang vacuum leaks...
Boostd1
PostPosted: Fri Oct 16, 2009 7:43 am    Post subject: Reply with quote
Hate them! But it's kind of bogus because the aftermarket adapter plate for the Gen V blower to a 97 throttle body totally doesn't cover up on of the passages Confused It was just a huge hole for unmetered air to enter the motor!
90droptoproc
PostPosted: Fri Oct 16, 2009 2:03 pm    Post subject: Reply with quote
JB weld!!
PostPosted: Fri Oct 16, 2009 2:49 pm    Post subject: Reply with quote
90droptoproc wrote:
JB weld!!
You sound like an early Rotary guy!
90droptoproc
PostPosted: Fri Oct 16, 2009 3:08 pm    Post subject: Reply with quote
lol
PostPosted: Fri Oct 16, 2009 4:47 pm    Post subject: Reply with quote
They like to weld up ANYTHING and EVERYTHING JB style. lol
90droptoproc
PostPosted: Fri Oct 16, 2009 7:28 pm    Post subject: Reply with quote
figure it's an aluminum adaptor, and just cause you and I can weld alum at home doesn't mean he can Razz
