Posted: Fri Sep 25, 2009 2:13 pm Post subject: Decel backfire |
When I shut the throttle after a hard wot pull the exhaust backfires loudly. During normal engine braking it's loud and poppy but doesn't backfire. Is there a way to fix this? I'm not sure where to start on this. _________________ E30
Posted: Fri Sep 25, 2009 3:51 pm Post subject: |
| Any exhaust leaks? |
Posted: Fri Sep 25, 2009 5:07 pm Post subject: |
More timing, lean out the carb.
Carbs don't have "Decel fuel cutoff" lol _________________ A redline a day keeps the carbon away! |
Posted: Mon Sep 28, 2009 6:27 am Post subject: |
I do have exhaust leaks. I still haven't put in the gaskets anywhere I'll put those on and see if it helps. My o2 sensor quit working so I'm not sure where my A/F is at WOT. Guess I better learn how to read spark plugs? |
Posted: Mon Sep 28, 2009 6:32 am Post subject: |
fixing the leaks should help. THe extra 02 in the system, combined with unburt fuel will certainly pop.
I say go with it, real cars shoot 3' flames out the exaust on the over-run.  |
kutison Member
Posted: Sat Oct 03, 2009 2:48 am Post subject: |
| I hear the popping when letting off at high RPM's, and I have an exaust leak too. so I'm glad I read this one |
