Head gasket quench questions
PostPosted: Wed Sep 23, 2009 6:53 pm    Post subject: Head gasket quench questions Reply with quote
Last time I had the 390 apart, I dropped for FelPro Performance headgaskets, not realizing that FelPro doesn't make a good shim-style gasket (Z1094) like they do for the smallblock, they just make these, which are basically stock-style:
http://www.summitracing.com/parts/FPP-1020/
The closest thing for material and thickness is this garbage:
http://www.summitracing.com/parts/MRG-1132/
Is it worth running those Mr. Crapouts to bring quench up? It's a pretty high compression engine, and I'll be down there swapping intake manifolds out, so it wouldn't be that much more work.
Any advice, guys? Shrug Shrug Shrug
PostPosted: Wed Sep 23, 2009 7:23 pm    Post subject: Reply with quote
Amazingly mr gasket steel shims arent that bad. Thats actually the only product of theirs I can think of saying that about too.
PostPosted: Wed Sep 23, 2009 7:47 pm    Post subject: Reply with quote
Oh really? So if I buy those, and use CopperCoat, I should be good to flog the snot out of her?
PostPosted: Wed Sep 23, 2009 8:46 pm    Post subject: Reply with quote
Got em in my 454. I really don't see how you can screw up a stamped piece of sheetmetal. And yes, coppercoat is the stuff.
PostPosted: Wed Sep 23, 2009 8:58 pm    Post subject: Reply with quote
The B seal of approval. Thumbs up
Thanks for the info, man. Now I got something to do after I move.
