90droptoproc Member
Posted: Tue Sep 22, 2009 11:32 pm Post subject: TV problems |
hey, a friend of mine just replaced a broken 700r4 in his blazer and it is shifting high, it has been years since I gave up on auto's and went stick in all my cars, can anyone remind me the best way to adjust the TV for him before he burns it up
thanks
Rich _________________
Posted: Wed Sep 23, 2009 12:29 am Post subject: |
Press and hold the D button on the TV cable bracket. Pull the cable all the way back towards the firewall. Release the button, then open the throttle by hand to WOT. That's how I've always known to set it. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
90droptoproc Member
Posted: Thu Sep 24, 2009 7:53 pm Post subject: |
thanks guys _________________
Posted: Thu Sep 24, 2009 10:15 pm Post subject: |
You're welcome  _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
