Practice for grid tail lights
PostPosted: Sun Sep 20, 2009 5:26 pm    Post subject: Practice for grid tail lights Reply with quote
Got my stock set down and cleaned them up. Then I used Night-Shades on them. A little darker than I wanted to go, but they look good. In the process, I found out my right side marker light is out. I haven't checked the reflectivity of the side marker lenses yet, needs to be darker outside, but a 1" strip of red reflective tape on the stripe should work for these. I don't know how I'd do the grids. Here's how they look.
Lights off...
Tail lights only...
The turn signals and backup lights are as bright, haven't checked the brake lights yet. I ran out of Night-Shades before I could do the center brake light.
lostinconformiti
PostPosted: Sun Sep 20, 2009 6:05 pm    Post subject: Reply with quote
looks good al, but will look better with the center brake light done.
PostPosted: Sun Sep 20, 2009 6:35 pm    Post subject: Reply with quote
looks sweet man
PostPosted: Sun Sep 20, 2009 7:33 pm    Post subject: Reply with quote
The standard tail lights don't look so bad when blacked out. I don't understand what your trying to say with all that red reflective tape stuff.
PostPosted: Sun Sep 20, 2009 7:38 pm    Post subject: Reply with quote
In order to be legal, your tail lights have to have red reflectors in them (they're in the side marker lenses). With them tinted, that reflectivity is significantly reduced, I still need to check how reflective they are from another car. These are a little darker than I intended to get them, so the grids may turn out OK.
PostPosted: Sun Sep 20, 2009 8:55 pm    Post subject: Reply with quote
Coming along nicely Al. Those lights will go well with the black wheels. Are the front marker lights and sidemarkers blacked as well? I can't remember.
PostPosted: Sun Sep 20, 2009 10:03 pm    Post subject: Reply with quote
lostinconformiti
PostPosted: Sun Sep 20, 2009 10:15 pm    Post subject: Reply with quote
dang al your car looks really good from the front!
PostPosted: Sat Sep 26, 2009 3:30 pm    Post subject: Reply with quote
I did the grids. They turned out a little darker than I had anticipated too. Maybe the angle, but sitting face up on the box I used, they looked a whole lot lighter. Light coming in from the back I suppose. Anyway, they turned out pretty good, not perfect, but I didn't have a perfect surface to work with as these came off a junkyard car a couple of years ago.
Here they are, I did the center brake light this time too...
And with the brakes on...
J-Dog-III
PostPosted: Sat Sep 26, 2009 7:58 pm    Post subject: Reply with quote
wow i think that looks really good...wanna do that to mine Sad
lostinconformiti
PostPosted: Sat Sep 26, 2009 8:34 pm    Post subject: Reply with quote
i think they are a little dark but it does look good.
PostPosted: Sun Sep 27, 2009 9:02 am    Post subject: Reply with quote
looks good but i dont think its to dark. alot of people do it really light and it dosnt looks as good. now my brothers accord when we nightsaded they turned out really dark.
before
after
PostPosted: Sun Sep 27, 2009 1:44 pm    Post subject: Reply with quote
Looks good, but you only did the top half. The red part was my concern for the reflector that's in there on the corner. Actually, mine aren't as dark as that picture shows. When covered by shadow, they look quite dark, but you can easily see the colors of the lenses with the sun on them.
PostPosted: Sun Sep 27, 2009 6:00 pm    Post subject: Reply with quote
LOL go look at my mazda... THOSE are dark.
PostPosted: Sun Sep 27, 2009 6:15 pm    Post subject: Reply with quote
The ones on your Mazda are dark. I think I got these where I like them. Next will be the purple car, but there's a little more work to pull those out Laughing Something to do with a stereo system, or something like that Very Happy
PostPosted: Mon Sep 28, 2009 5:34 pm    Post subject: Reply with quote
are you able to see the brake lights if there in direct sunlight?
PostPosted: Mon Sep 28, 2009 6:02 pm    Post subject: Reply with quote
Yes I can. That and the reflector on the corner lights were my main concern and why I didn't go any darker.
PostPosted: Mon Sep 28, 2009 9:26 pm    Post subject: Reply with quote
Anyone find some LED lights to fit in stock spots that are ACTUALLY brighter? Most say they are but Alloy ended up with some that weren't all that bright IIRC.
PostPosted: Mon Sep 28, 2009 10:19 pm    Post subject: Reply with quote
The only plug & play ones I found that might do the trick are like this.
They open up once you put them into the housing. They also have LEDs on the back side (though not many) to utilize the reflector.
I can't find a price for this though, but I've seen it as high as $70 per unit.
PostPosted: Tue Sep 29, 2009 4:00 am    Post subject: Reply with quote
http://www.spaghettiengineering.com/comersus/store/comersus_viewItem.asp?idProduct=65
http://www.northwestmustang.com/camaro1982.html
Two companies that make LED tail lights for Camaro's.
