Cascade Crew Message Forums
Posted: Sat Sep 19, 2009 8:27 am Post subject: Ouch! (a rant, don't mind me) |
So I get an e-mail last night from Ford Powertrain Applications:
| Quote: | from fordpowert@***
to <***>
date Fri, Sep 18, 2009 at 11:03 PM
subject Re: Tri-Y Galaxie headers
mailed-by comcast.net
Bare, no coating, $550 + $55 shipping. Hi Heat cerma coated, inside and out, baked and polished for $775 + shipping. All hardware included . We are currently 10 days back logged but the order desk will be closed from Sept 24 to Oct 9 but production will continue and all ordered placed before 9/23 will be processed and shipped.
Stan F.P.A Ford headers
253 848-9503 Pacific time 9-6 Mon-Fri |
So their prices have gone up, and they weren't cheap to begin with. The only problem is that there are only three companies that make headers for the early fullsize Fords: Crites, FPA, and Sanderson <- (cheap short-tube junk).
These are the Crites:
Never mind the wrong date, the ones for older cars are similar. Those gargantuan things have 2 inch primaries, and 3 1/2 inch collectors! Also, the front four cylinder primaries drop down in front of the crossmember. The good news is that they cost a mere $329 + shipping.
Now I shift at 6 grand on an engine with a true displacement of 395ci, but jesus christ I doubt I'll ever need two inch primaries. Not to mention that this car originally had a set of those on it when it was first built, but the previous owner nailed them on a pothole, and had to revert back to T-Bird logs. <- (logs + big block = teh suk)
Anyway, this post turned into kind of a rant, but that's whats going on in Ford-land. I'll probably pick up the Crites, and go in a little bit different direction with this motor. When I put it together I was worried about losing low end power in such a heavy car, so I kept everything small (low dual-plane, small Holley, stock converter). In hindsight that was kind of a mistake. The FE makes stupid power through the band, but right now it's strangled above 4K, mostly due to the exhaust. Plus the converter stalling at 1900 sucks.
1500-6000 powerband, here I come.
Posted: Sat Sep 19, 2009 9:37 am Post subject: |
Been doing some math... Crites uses .090 tubing for their headers ( ) giving me a primary ID of 1.82". That calculates to roughly a peak torque of 4650rpm with my engine, assuming interwebs header calculators are right. |
Posted: Sat Sep 19, 2009 9:45 am Post subject: |
That doesn't sound bad. My custom tri-Y headers for the firebird were almost $800 10 years ago. They were made by Lemon's one off for me and are a work of art. Of course, they messed up and used the wrong tranny for the mockup so I got them for half price because they didn't want to redo the job. That's why I have a TH400 now instead of the Tremec.
If you pay too little for a header then it won't last and will leak exhaust. |
dlp Member
1990 Chevrolet Camaro IROC-Z
Posted: Sat Sep 19, 2009 11:21 am Post subject: |
| Try Stans Headers in Auburn. For 750+ you may be able have a set of stainless steel headers made. |
Posted: Sat Sep 19, 2009 12:01 pm Post subject: |
$750 is what I paid for my Stainless Works headers. However, it is probably the only part I have ever installed that went in without a hitch. No pounding, no cutting, nothing. I was scared.
Crites probably uses that thick because they know they'll get pounded being infront of the crossmember!
| dlp wrote: | | Try Stans Headers in Auburn. For 750+ you may be able have a set of stainless steel headers made. |
Good place. Had mandrel my catback made there. _________________
