any ideas?
PostPosted: Fri Sep 04, 2009 6:53 pm    Post subject: any ideas? Reply with quote
well the camaro is having a problem. its really struggling up hill and if u give it to much gas to quick it hesitates really bad then makes a small pop noises and takes off and it seams to do it worse the hotter the engine is. anyone have any ideas what it could be
PostPosted: Fri Sep 04, 2009 7:21 pm    Post subject: Reply with quote
Coolant sensor, o2 sensor, clogged cat... it could be several things, you need to check stuff out.
PostPosted: Fri Sep 04, 2009 7:41 pm    Post subject: Reply with quote
ok ya.tho im sure its not the cat cause that is fairly new
PostPosted: Fri Sep 04, 2009 8:07 pm    Post subject: Reply with quote
EST wire unplugged?
PostPosted: Fri Sep 04, 2009 10:55 pm    Post subject: Reply with quote
EST wire unplugged?
i dont know how it would be but ill check in the morning
Saber
PostPosted: Sat Sep 05, 2009 4:39 am    Post subject: Reply with quote
is the popping sound coming from up front? that's the same thing my car is doing cuts out and pops when i take off and i pretty much have to drive at high rpms mine is cause my car is running in limp mode and that's actually what its called i have a bad fuel pump and missing my mass air flow sensor not saying that's what's wrong with your car but have it looked at cause its doing the same thing my car is. by the way is your check engine light on?
View user's profile Send private message Send e-mail Yahoo Messenger
TurdGen1989
PostPosted: Sat Sep 05, 2009 6:37 am    Post subject: Reply with quote
just save yourself the trouble as i failed to do so... just go buy a $28 coolant sensor and be done with it lol
Phil.
GMC High Sierra
PostPosted: Sat Sep 05, 2009 9:12 am    Post subject: Reply with quote
You definitely wanna get that MAF back in there.
Pops up front are from too advanced timing or lean conditions.
Pops out the back are from too retarded timing or rich conditions.
Saber
PostPosted: Sat Sep 05, 2009 10:18 am    Post subject: Reply with quote
you can hear it coming from front and back and i have to have the maf sensor out tell i fix the fuel pump or the computer doesn't read the pump is going so the car won't run at all
PostPosted: Sat Sep 05, 2009 10:49 am    Post subject: Reply with quote
That doesn't make any sense?
Maybe if the pump is bad as you suspect, the readings from the MAF make the mixture too lean because the computer runs based on full pressures. Running in limp home mode like this is a bad idea.
You could be running so lean you melt some pistons.
PostPosted: Sat Sep 05, 2009 1:54 pm    Post subject: Reply with quote
well i dont hav any engine lights on and the poping sound is coming for the front so now im thinking its the coolant sensor cause wouldnt that cause it to run lean? plus my car seams to have cooling system problems almost all the repairs that this car has had i the past few years have been coolant related first the radiator then the heater core then the coolant temp sensor and the water pump has been making noises since iv owned the car so y wouldnt it be time for this sensor to go
PostPosted: Sat Sep 05, 2009 2:54 pm    Post subject: Reply with quote
The coolant temp sensors I've seen fail have failed max cold, and cause the engine to run rich. Yours sounds like a lean condition.
Are you overheating? Overheated engine will ping and have no power.
PostPosted: Sat Sep 05, 2009 3:00 pm    Post subject: Reply with quote
nope no over heating but it seams to run a tad bit hotter tho
PostPosted: Sat Sep 05, 2009 3:05 pm    Post subject: Reply with quote
Lean condition causes the engine to run hotter. Check fuel pressure, and timing.
Saber
PostPosted: Sat Sep 05, 2009 8:42 pm    Post subject: Reply with quote
by the way i had a shop check out my car and im only running 25 pounds of pressure and they told me my car should be pushing 44 pounds
PostPosted: Sat Sep 05, 2009 9:25 pm    Post subject: Reply with quote
Saber: I'd verify their readings. What shop did you take it to? You're local so I'll now most shops.
Cameron:
Spend the $7 and get a 180ºF Thermostat. Standard V8 Small Block Chevy w/ gasket.
Run something like chevron or shell vas.... 92 octane..... NOT arco, 7-11,etc... and get back to us... Twisted Evil
Saber
PostPosted: Sat Sep 05, 2009 10:22 pm    Post subject: Reply with quote
its a local mechanic in Gresham one of my grandma's good friends owns a shop think its called cleveland autos
lostinconformiti
PostPosted: Sun Sep 06, 2009 2:52 pm    Post subject: Reply with quote
Cameron:
2NDED!
PostPosted: Sun Sep 06, 2009 4:54 pm    Post subject: Reply with quote
Cameron:
ok tomarrow ill pick up the 180 thermostate and just for the hell of it ill grab a coolant sensor (if there open on labor day that is). and i normaly run 89 octane but ill do 92 now and i try to stay away from 7-11 and arco and places like that but there is safeway gas that i have been running in it cause with discounts i could get it for like 2.50 a gal but i thought it would bit me in the ass. but i stoped runing that when this problem started but right now i got a full tank of 89 octane from 76(im not sure good 76 gas is) with fuel system cleaner but ill see about addin some better gas soon
PostPosted: Sun Sep 06, 2009 5:53 pm    Post subject: Reply with quote
Safeway gas sucks. Same with Costco and Fred Meyer. Try Shell or Chevron premium. I do run Arco 87 in the truck, but I have to detune a bit for it.
