Posted: Tue Aug 04, 2009 5:37 pm Post subject: I think I owe Paul an apology |
A few years back when I was a n00b on these forums, Paul (Twilightoptics) and I got into a little debate over whether improving exhaust flow would help or hurt gas mileage.
I always thought freeing up the exhaust would increase mileage, he said it would result in a drop. Today I did a little bit of calculating on the S10's mileage, and it is down about 1-2mpg after installing the Hedman's, the new Y-pipe, and Magnaflow.
I've also noticed that it doesn't like nearly as much timing, so there must have been enough backpressure to cause some sort of self-EGR.
You were right, dude!  |
Posted: Tue Aug 04, 2009 5:42 pm Post subject: |
There is no such thing as back pressure.
You overbuilt the exhaust system. The optimum was somewhere between stock and where you are now. |
Deja vu.  |
Posted: Tue Aug 04, 2009 5:47 pm Post subject: |
What John said.
:O)
You might seem an improvement if what you had was less than what the engine needed, and what you have now is what it needs.
If you go too big, you lose velocity and thus some milage from the low rpm loss.
:O) _________________ A redline a day keeps the carbon away! |
Posted: Tue Aug 04, 2009 5:55 pm Post subject: |
I want to know why did you spend all that money on performance parts for an S10?  |
Posted: Tue Aug 04, 2009 6:14 pm Post subject: |
Pfft. $170 for painted Hedmans isn't a lot of money.
Plus it does a nice pegleg burnout now.  |
Posted: Tue Aug 04, 2009 7:02 pm Post subject: |
I agree. $170 is a good value.
You should have a custom license plate, "PEG LEG" |
85 T/A WS6 Member
1985 Pontiac Trans Am
Posted: Tue Aug 04, 2009 10:11 pm Post subject: |
| QwkTrip wrote: | | There is no such thing as back pressure. |
Nope, there is no back pressure, and there is no spoon! |
Posted: Tue Aug 04, 2009 11:24 pm Post subject: |
No, Free lesson for you...
http://www.thirdgen.org/techboard/exhaust/338421-more-than-you-ever.html _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Wed Aug 05, 2009 4:15 am Post subject: |
That's just a marketing blurb from a company website. We all know what engineers think of marketers, right?
I've done graduate level compressible flow and fluid dynamics. Back pressure is a slang term and a misconception that leads people to incorrect conclusions because it implies that pressure is directional. Pressure isn't directional. A pressure differential causes air movement in the exhaust. And then because of the wildly complex nature of air flow and combustion there are other phenomenon that also cause pressure differential in the exhaust system.
You're going to find all kinds of differing opinions on what is the best exhaust system because the science of air flow and combustion is still developing. Compressible air flow is a baby concept in the world of science and wasn't even developed until the supersonic flight age. We're talking about a science that is only about 60 years old! |
85 T/A WS6 Member
Posted: Wed Aug 05, 2009 11:09 am Post subject: |
Slang or not, its widely used by many in the auto industry.
It can be measured (helps to detect a bad cat for example)
It is what makes a 2 stroke engine work.  |
Posted: Wed Aug 05, 2009 5:07 pm Post subject: |
Those people were in the first rounds of layoff, I'm sure. They probably work for Supertrapp now
You can't measure back pressure. What would be the units of measure? You can measure pressure, though.
So here's a parallel example to the plugged catalytic converter. I'm a little aware of diesel particulate filters (DPF) and the development happening at my company. When they needed to know if the DPF was plugged they had to use two pressure sensors to measure the pressure drop across the DPF honey comb. That's 2 sensors that cost money. There wasn't a section in the catalog called, back pressure sensors. Believe me, if they could save money by using one sensor they would have done it!  |
85 T/A WS6 Member
Posted: Thu Aug 06, 2009 2:45 pm Post subject: |
Putting "back" in front of "pressure" just helps you define where its at in a system. In turbo charging, back pressure is good on engine port but bad on the turbine outlet. This is the only automotive area that really applies to compressible flow.
Here it is, the test kit!
http://www.sjdiscounttools.com/waebpt01.html
It is here, we have it now.
Some Ford Powerstokers use a exhaust back pressure valve
That silly Flowmaster company talks about back pressure here.
http://www.flowmastermufflers.com/backpressure.html
And here is Magnaflow giving lip service to the same thing
http://www.magnaflow.com/05news/magazine/05sportcpg02.asp
The campaign to eliminate the term back pressure will fail.
Long live the Leaf Blower! |
Posted: Thu Aug 06, 2009 5:01 pm Post subject: |
| 85 T/A WS6 wrote: | The campaign to eliminate the term back pressure will fail.  |
Probably. |
Posted: Fri Aug 07, 2009 1:54 am Post subject: |
| 85 T/A WS6 wrote: | | In turbo charging, back pressure is good on engine port but bad on the turbine outlet. This is the only automotive area that really applies to compressible flow. |
That isn't true either. The turbo works on the pressure difference on either side of the turbine wheel. To get the pressure difference, you have to have pressure on the engine side of the turbo. You get a pumping loss from the engine with this pressure though. It is a trade off. In a perfect world, you would have no pressure on the engine exaust port, but also get the pressure change to spin the turbine. That pesky physics thing wins again, and we have to have pressure on the engine side of the turbo to get it spin.
I agree with Jon's point, but at the end of the day, people call it what they call it. |
Posted: Fri Aug 07, 2009 11:49 am Post subject: |
To add to that, air is a compressible fluid so any air flow problem is governed by compressible flow.
I designed turbine blades in college. There was no mention of back pressure and the word can't be found in my text books (just checked). I'll bet money on McGraw Hill over Supertrapps and Magnaflow any day. Most people used to believe the world was flat, too. Popular opinion usually overcomes truth.  |
85 T/A WS6 Member
Posted: Fri Aug 07, 2009 11:59 am Post subject: |
Turbines rotate because of enthalpy difference, which inlcudes pressure, but also includes temperature and velocity. Good turbo design maintains enthalpy by maintaing outlet velocity, (engine port to turbine inlet). The statement I made specifically applies to turbos, not NA engines.
By the way, a turbine would spin, with no pressure difference because of the flow of exhaust gases. This would require a large, inefficient turbine design. How does a water wheel, running in a stream turn? No pressure difference there, just water flow.
Compressible flow doesn't apply much in typical NA engine exhaust systems. Yes, exhaust gas is compressible, but the flow velocitys are so low it doesn't matter. There isn't much mystery in design of automotive exhaust systems, just mostly hype as vendors try to convince people that they have a new idea.
Not trying to bust chops here, I just wish you guys would take off the lab coats for once lol. |
Posted: Fri Aug 07, 2009 12:23 pm Post subject: |
| 85 T/A WS6 wrote: | | ... I just wish you guys would take off the lab coats for once lol. |
ACK!
With this group be careful what you ask for.
:commando:
Posted: Fri Aug 07, 2009 12:27 pm Post subject: |
I did get rained on pretty hard today and had to go home and chance my clothes. You better hope I didn't forget anything in the rush! |
