More Injector Q's
PostPosted: Mon Jul 20, 2009 6:37 am    Post subject: More Injector Q's Reply with quote
So I am quite sure the "new" injectors I have are plugged as well the ones I pulled out (thats why I got diff ones)
So searching for more. Car has 21.6/22lbs in it now. I am wondering what other side effects I would have if I went to some 30lb and adjusted the pcm for it?
faster injector pulse? any downside?
anything else?
PostPosted: Mon Jul 20, 2009 7:41 am    Post subject: Reply with quote
The only thing I have heard is you start to loose the ability to meter fuel at small pulse widths. Since the injector has to flow such a large amount of fuel the holes don't do well at small flows, not as well as a smaller injector would.
PostPosted: Mon Jul 20, 2009 9:06 am    Post subject: Reply with quote
You think 30lb would be to much? I do plan to go to the alumn vette heads, or maybe vortecs in near future.
Remember that I'm also OBD2.
Have a friend who wants to turbo it, but doubt the cash will be found to do it.
PostPosted: Mon Jul 20, 2009 9:35 am    Post subject: Reply with quote
I would run the BSFC numbers and see what you need. The LT1's come with 24lb/hr injectors and the corvette engine puts out 300hp (camaro 275).
PostPosted: Mon Jul 20, 2009 10:08 am    Post subject: Reply with quote
30's aren't too big.
With MPFI losing idle pulse width isn't as big an issue as with TBI.
Run 24s if you're not planning to go over 300 RWHP.
PostPosted: Mon Jul 20, 2009 11:30 am    Post subject: Reply with quote
300 is my goal with n/a. But in looking for 24s', seems I can get 30's cheaper then 24's because of less people bidding on them (evilbay).
PostPosted: Mon Jul 20, 2009 1:49 pm    Post subject: Reply with quote
Heh and you think you've got injector problems now.
Something like that I wouldn't buy used.
Ford SVO from summit are a steal. 24s or 30s they even flow more than the standard rating because Fords lb/hr measurement is at a lower pressure. So they flow more like 25.5 or 31.5...
PostPosted: Wed Jul 22, 2009 6:25 am    Post subject: Reply with quote
Paul's right. The SVO 30lb I just bought were a really good deal. They're $240 from Summit right now.
Doesn't look like there are any 24lb ones on there though.
http://www.summitracing.com/parts/FMS-M-9593-BB302/
EDIT: At the risk of sounding dumb due to speaking from memory, Ford flows their injectors at 39.5psi. That's the number I recall. GM flows theirs at 43psi. Hence the Ford ones at 43psi in a GM system actually flow about 8% better.
