If somone could help me program a chip.
BigBoi4Lyph
PostPosted: Mon Jul 13, 2009 7:41 pm    Post subject: If somone could help me program a chip. Reply with quote
So i dont have the cash to put out for all the programing stuff i need right at the moment to tune my iroc.
im hopeing one of you guys around my area olympia,wa that has the equiptment if i buy a prom if we could meet up and help me get a chip made.
the initial timing is driving me nuts (i converted from an auto the manual. i beleave the timing tables are different and thats why it boggs a little when im letting out the clutch.)
anyhow let me know i would apriciate it much and i could come to you. met up and talk 3rd gen for a while!
David
87 Camaro Z28 - Iroc-Z
PostPosted: Mon Jul 13, 2009 9:13 pm    Post subject: Reply with quote
Have you verified your actual timing?
I've run chips on both manuals and standards and seen no difference.
In fact most guys that convert to a manual, it works just fine.
PostPosted: Mon Jul 13, 2009 9:19 pm    Post subject: Reply with quote
Paul, on my '87 the stock idle/off-idle timing was like 20* straight across for an auto, but the manual dropped off on the high end of the scale.
I bumped it up to about 26* till 1200rpm, then ramped from there as usual, and it made a huge difference in the feel of the clutch. Much less bog than before.
PostPosted: Mon Jul 13, 2009 9:21 pm    Post subject: Reply with quote
Further proves that not all engines are the same.
90droptoproc
PostPosted: Mon Jul 13, 2009 9:43 pm    Post subject: Reply with quote
ya, had to burn a chip when we went from auto to standard
I was able to drive it, but it would stall out when you came to a stop and held in the clutch (stop lights)
PostPosted: Mon Jul 13, 2009 9:49 pm    Post subject: Reply with quote
Could also be a VSS issue. Without it getting a good signal your timing will be retarded, and your idle will start creeping up at lights.
PostPosted: Tue Jul 14, 2009 7:09 am    Post subject: Reply with quote
...your timing will be retarded...
No YOUR timing will be retarded...
PostPosted: Tue Jul 14, 2009 9:28 am    Post subject: Reply with quote
Says the man with an automatic and a carb. Pokey pokey
PostPosted: Tue Jul 14, 2009 9:30 am    Post subject: Reply with quote
Laughing I know i know... I like the carb action, but i really miss shifting.
PostPosted: Tue Jul 14, 2009 10:32 am    Post subject: Reply with quote
shifting is over-rated :p
PostPosted: Tue Jul 14, 2009 11:40 pm    Post subject: Reply with quote
Coming from the guy who races people with his tires going faster than the rest of his car! Laughing
'88 FORMULA
PostPosted: Wed Jul 15, 2009 6:10 am    Post subject: Reply with quote
Hmmm.... True....
BigBoi4Lyph
PostPosted: Thu Jul 16, 2009 7:02 pm    Post subject: Reply with quote
yea. it just boggs just a little if i do a soft launch if i keep the rpms higher when i take off its fine but on a soft normal launch you can feel it.
base timing is good.
beyond tunning for the swap just generally it needs some things changed from no a/c and smog.
but if anyone can help me that would be sweet. let me know
Mangus
1989 Pontiac Trans Am
PostPosted: Sun Jul 19, 2009 4:07 pm    Post subject: Reply with quote
IAC params are generally quite different between auto and manual. Your best bet, in my opinion, is to find the stock bin for the new transmission style that you've changed to (e.g. start with the stock manual bin for the same year, engine, etc if you swapped to a manual transmission) and tune from there.
